First post, by sulax
Recently purchased a new PC with i7 Core processor.. however facing serious problems in configuring the same for some of older DOS based applications...
1. Will DosBox run on Window 7 ?
2. The PC motherboard is not equipped with a Parallel Port. If I install a PCI
Parallel port will that port be easily accessed for some of the applications
which uses Parallel Port from DosBox 0.74 ... if yes how the application
that used Parallel port can access the PCI Parallel port.
