First post, by retro games 100
I'm testing a 486 VLB mobo. It's made by QDI, and called a V4P895P3 / SMT V1.0. I browsed for this mobo online, and discovered that all revisions of it can accept an AMD 5x86 CPU, except the revision I have. Oh well.
Undertered by this inconvenience, I decided to try out some other CPUs, such as a POD83 and an Intel DX4-100 write back CPU. However, the mobo will not POST if either of these CPUs have the mobo jumpers set to "write back" mode. If I set the mobo jumpers to "write through" mode, then the mobo will POST with these CPUs.
There are lots of revisions of this mobo. I think there are at least 5 of them. I had a look online for the jumper information, and found them here and here. There is also information printed on the mobo. I think I've got the jumpers right. What could be causing this problem? Has anyone had this kind of problem? Thanks a lot for any clues! 😀
The BIOS POST screen says this:
OPTi895CP3 GREEN PC IVN1.1C 30 Sep, 1994
40-0b08-008003-00101111-121593-OP802G-H
AMIBIOS date of 12/15/93
Edit. Possible pilot error - For the DX4-100 WB CPU, I used the P24D jumper settings. But a P24D is a write-back DX2 CPU. I'll alter the jumpers, and change them to the DX4 jumper configuration. However, there is no mention of setting for a DX4 CPU to work in "write back" mode. It's possible that the DX4 WB CPU is not fully supported. However, the P24T (POD) in write back mode should work, because on the mobo's PCB, it says that jumper JP4 controls whether the POD is in write back mode, or not.
Edit 2. I set the jumpers for a DX4 CPU. It POSTs, but the CPU is not working in write back mode. I suspect that there is no option for a DX4 in write back mode. I will dig out a P24D (DX2 write back) CPU, and see if that works correctly in write back mode...
Edit 3. Whoops. The mobo will take its secret to the grave. I put in a P24D, and it wouldn't POST at all, in either WT or WB mode. I replaced it with a DX2-66 (enhanced WT) CPU, and because of tiredness and poor lighting conditions, I put the CPU in the wrong orientation. Horrible burning smell. Dead board. The other bits are OK though. I haven't tested the CPU. It might still be alive.
Reply 1 of 14, by Tetrium
Ouch...
Good chance the CPU is toast. The board "might" still live, but consider yourself lucky if that is the case 🙁
My retro rigs (old topic)
Report spammers here!
Reply 2 of 14, by retro games 100
Here's the damage. The burning smell has nearly gone. Stupid question - do you think it's worth switching it on again? The "black blood" is only on two pins. Worth a go, or not? Does anyone know what those 2 "charred" pins do? You can work out the orientation of the socket, because the "CPU corner" part is in the top right part of the photo.
The mobo might be able to "limp along" without the need for those 2 pin bits to work. Or it might just start a fire.
Reply 4 of 14, by retro games 100
I just tried the CPU that was in the mobo when it started to burn, and it still works! (I tested this CPU in a different mobo.) I haven't tried the "burnt" mobo yet. BTW, all of the other components taken from the burnt work too - PSU, RAM, VGA card, etc. I doubt if the burnt mobo will work, but I might try it tomorrow morning. I could power it on with nothing in it first, to see if it starts to burn again...
Reply 5 of 14, by 5u3
Just noticed on the photo that your board doesn't have a voltage converter (see the silkscreened rectangles just east of the CPU socket), which means it runs all CPUs with 5V. So be careful and only try "cheap" CPUs.
Reply 6 of 14, by Tetrium
^agrees
Try it with an expendable CPU.
One odd thing, why are 2 of the most outer pins burnt? Those pins are only used by the POD?
Could it have been an incorrectly placed jumper?
Reply 7 of 14, by retro games 100
Thanks a lot for the info, people. Guess what? It's alive! RG100 destroyer of old hardware? I think not! I just wounded it, that's all! 😉 I think that I have been incredibly lucky. I went to this webpage. There, I went to page 7. On it, it shows you a "pin out" diagram of a 486 33MHz CPU. I have copied a bit of it, and it appears below.
I tested the board with an enhanced 486 DX2-66, non writeback model, and it seems to work OK. Tetrium, do you think the location of the 2 burnt mobo socket holes would affect a POD83 CPU? If so, I won't try one. Instead, I'll just use this board with less powerful CPUs.
Regarding the jumper settings for a 5x86, I believe that there are two issues with this. Firstly, as 5u3 pointed out, there is an absense of a voltage converter. Also, the other issue with using a 5x86 is that I have version 1 of this mobo, and reading about this mobo on the net, I believe that it has no support for this CPU.
Reply 8 of 14, by udam_u
@rg100
I damaged my first computer in the same way as you - motherboard did not survive but CPU is still alive! (:
I think that you shorted Vcc (positive supply voltage) to Vss (ground) by putting CPU in wrong orientation. Then the current flew and the weakest wire burned. However your motherboard can still operate if your CPU doesn't use damaged wire. I'm sure that not all CPUs make use of all Vcc and Vss pins.
Regards! [:
EDIT:
Good investigation! (: I'm glad that your motherboard works correctly.
What doesn't kill you makes you stronger.
Reply 9 of 14, by retro games 100
udam_u wrote:
... I'm glad that your motherboard works correctly.
So am I! 😀 I booted up the mobo using Windows 98 SE. It seems to work fine. Here's a quick test, using WinTune. It's nothing special, but just shows that it works. It's useful to have a couple of "crappy" mobos lying about, for testing purposes. I like this mobo, because it survived after having been "shot in the arm". 😉
Reply 10 of 14, by Tetrium
Lucky git!! ;D
And with such burn marks (and plenty other boards available 😉 ) I wouldn't even consider "just trying" a POD83 "just for the heck of it" 😉
Reply 11 of 14, by Flashy
5u3 wrote on 2011-05-04, 23:40:
I have the same motherboard with no voltage regulator and the place of the voltage jumper is hardwired to closed position. But the mb works with Intel DX4-100 and AMD 5x86-133-P75 CPUs so it must have autodetect feature. I have not tested it long, but it did not kill the CPUs on instant, and Quake and Doom timedemos run well. Sadly these are old motherboards with very little information on the internet and even those documentations does not fit the motherboard...
With the AMD 5x86-133: the WB-WT jumper have to stay open, in one setting the mb did not post, in the other it detected only 640k of memory. One interesting thing is that my CPU was detected with cpuid 4E4 before I started to try the WB/WT jumper, and now it detects as 4F4 (it was only 1 jumper and I removed it, so nothing was changed permanently). It may be some instability, the CPU socket is not perfect, but interesting because it totally works, only with different cpuid.
(I know the thread is old, but these forums are useful until the last of these old motherboards die)
Reply 12 of 14, by fgenesis
Does anyone have a BIOS dump for this mainboard? v1.0 specifically.
http://www.win3x.org/uh19/motherboard/show/5568 has a few newer ones but those don't seem to work;
I've tried a v5.0 ROM with the chip inserted the weird way as on the picture in the first post but the board doesn't POST past the RAM test ("D3D2" via debug card) no matter if RAM is inserted or not. No beep or video.
Background: Found two of these boards both fitted with an AMD 80MHz 486 DX2 but someone took the cache chips and the BIOS chip. Cache was easy to fix, but the BIOS isn't available anywhere on the net at this point ...
EDIT: Someone has v3.0 (attached here for convenience) but that doesn't work either, same behavior.
V4P895P3_SMT_V3.0.BIN.zip
59.32 KiB
63 downloads
Mirrored from linked post for future reference
EDIT#2 for future visitors and time travellers: I was unable to obtain a QDI 4P895P3 / SMT V1.0 BIOS. But turns out that UH19 has a very similar board, TMC PAT48PG4, with an Award BIOS but for the same chipset (OPTi 82C895). That one works! Attached just in case.
bios-award-pat48pg4-1.20-5ff0830b7a203892941221.zip
44.58 KiB
64 downloads
TMC PAT48PG4 BIOS from UH19
EDIT #3 there is also a OPTi895 variant of MR-BIOS in the big bundle at vogonsdrivers, but that doesn't seem to work on my board (POST gets stuck very early).
EDIT #4: Turns out that with the above BIOS normal ISA VGA cards work fine but my Speedstar Pro VL is extremely unrealiable on this board and it only POSTs when capacitors are discharged after leaving it alone for so long. I tried a few BIOS chips from other mainboards and the one from a MS-4123 (Sis896 aka 82C896 chipset) also works and POSTs everytime now. So this is a good alternative to try.
MS-4123-bios.zip
41.79 KiB
58 downloads
EDIT #5: Previous attempts either didn't detect RAM properly or were unstable. After trying ALL of the currently available BIOSes for that chipset on UH19 i've settled with the Award BIOS for this board. Mirrored file:
j-403tgawd-5edfb2216a0b8121722167-5fb4063a59160522204413.zip
44.32 KiB
53 downloads
Verdict: This is one bitchy board. I'm not surprised they needed over 5 revisions to fix their shit.
Some AMI BIOSes outright don't POST at all. Others do but only detect 640k RAM. When they boot they work fine with the speedstar card, but won't POST when any sort of IO expansion card is present, VLB or not.
The Award BIOSes seem to have more trouble booting, most don't like the VLB card. With the last linked BIOS i've got it to a state where it is fine with the speedstar VLB card and a non-VLB IO card. It won't POST with two VLB slots used but at least it's in a state now where the hardware is somewhat usable.
Reply 14 of 14, by Charleston
I'm having so much trouble with this board myself actually, the rev 1.0 like in the original post. I can get it to post at 50mhz on a dx2 and that is it. I can not for the life of me get the jumper settings right on the dx4 100.
I thought I had it figured out when I got the 50mhz to post but now I'm at a loss. The 100mhz will post at 5v but obviously that's not a good idea. Is the voltage regulator dead in mine or something?
