First post, by elsulet
Hi All,
I'm very new to DosBox and would like to play WolfenStein 3D 😊
Before that I have to say I use a Windows 7 Family Premium on a 64 notebook box, and as I'm French, the keyboard has the same layout.
The CPU is an Core i5 M460 running at 2.53GHz.
It has 4GB of RAM. The sound card is integrated to the motherboard.
I start DosBox 0.74 from the shortcut on the desktop just after I install it, and get two windows :
- One which title is DoxBox Status Window, displaying :
DOSBox version 0.74 Copyright 2002-2010 DOSBox Team, published under GNU GPL. --- CONFIG:Loading primary settings from config fi […]
DOSBox version 0.74
CONFIG:Loading primary settings from config file C:\Users\ElSuket\AppData\Local\
DOSBox\dosbox-0.74.conf
MIDI:Opened device:win32
DOS keyboard layout loaded with main language code FR for layout fr
- And another one which title is DoxBox 0.74, Cpu speed : 3000 cycles, Frameskip 0 Program: DOSBOX
I'm trying to type the MOUNT command in the second window to map my games folder, but it doesn't display any characters. A stroke on the Enter key does not change anything.
I thought lowering the number of cycles could have an incidence, but it doesn't.
I then set the keyboardlayout=fr in the C:\Users\ElSuket\AppData\Local\DOSBox\dosbox-0.74.conf file, and restarted DoxBox, but it has no effect.
Can you shed some light ? 😀
Thanks for your help !
