First post, by Unregistered
hey all the smart guys!! I really need some help!
The music in my dos game is really choppy and laggy!
I've read all the comments about sound configuration~
The solutions that I've gather so far are as follow:
Under the file [VDMS.ini]:
- Change the minDMAPeriod and maxDMAPeriod in the [DMA Transfer Manager.config] section.
**(The dafault value was min = 5 and max = 15. My music is laggy so what value should i change? what are the max and min value anyways??)
- Change the sample rate under [SB Controller.config] section.
-change the buffer value for both [AdLib Controller.config] and [SB Wave Player.config] sections.
**What happens when the values are high? low? what are their max and min value anyways??
Please Help me!! I will be very apperciated!!
