First post, by kruelaid
hey i just recently bought rayman forever and i entered these commands in dosbox in order to run it
mount a c:\oldgames
mount c e:\ -t cdrom
cd rayman
install.bat
the installer opens up fine but when i go to select the drive to install two it isnt there. please help!
Reply 1 of 3, by bloodbat
Why are you mounting as a what traditionally is a c: hard drive? Why are you mounting as c what is traditionally d:, a cdrom? It might or might not be important...
Also, you're never changing the active unit, if that's all you typed.
so, I'd do this:
mount c c:\oldgames
mount d e:\ -t cdrom
d:
install.bat
