First post, by Timm Sodtalbers
Hi!
Is it possible to start DOSBox without any dialogs (silent mode)?
I have written a program that needs to execute a 16-Bit application several times and I would like to use DOSBox for that in 64-Bit Window 7 environments.
Best regards
Timm Sodtalbers
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
sure set up right configuration files and/or parameters.
At least if you mean with dialogs, the fact that you need to type something.
Water flows down the stream
