F2bnp wrote:So voltage is fixed, kinda like the multiplier in many CPUs?
What I meant to say is, it's not that Tualatin won't work on the CUSL2 because it doesn't support the lower voltage (because it does!), but because Intel on purpose, switched a couple pins around because they knew it wouldn't work anymore in the old Coppermine boards 😉
Edit:What I wrote is a bit confusing. If Intel had NOT changed switched those pins, Tualatins would work in every s370 board that supported it's lower voltage. Not sure what all that AGTL+ stuff is about, but apparently it doesn't really matter for us with regards to messing around with retro hardware 😉
What the mentioned adapters do is to actually switch those pins back (or perhaps block them altogether) so that the switched pins of the Tualatin won't cause the Coppermine board to not boot anymore.
You can accomplish the same by doing some pin modding, but many find that using an adapter is simply less of a hassle 😉
