First post, by KeenCommander
It seems it is possible to have 2 joysticks working in Dosbox, but only with 2 buttons. I hope they are still working on joystick support with 4 or more buttons.
Is it possible to use the left control instead of the little stick
For some reason Dosbox keeps using the stick. I can't change anything in the windows driver or choose which way the joystick is used in DosBox.
Reply 1 of 3, by Good Ol' TarviS
Have you tried the MODE button on the controller? It swaps the inputs given by the left stick and the D-Pad.
Reply 2 of 3, by leileilol
That is true. It's one of the best buttons ever for purposes like this.
long live PCem
Reply 3 of 3, by KeenCommander
Wow, that worked 😀
Thanks a lot!!!
