First post, by SumElementum
Mega Man X, CD-ROM, 1993
Requires:
Dos 5.0 or higher
486-33 Mhz min.
Double Speed CD-ROM Drive
VGA Graphic Card
4MB of Memory/ 6MB of Hard Disk Space
I'm currently using Windows Vista
Well, all I want is to run the full game, period. I have DOS Box, as well as D-Fend Reloaded, but not familiar enough with them.
On D-Fend Reloaded I can only play the first level. When I try to load my game after that it just shuts down.
If I start over the installation process, how would I go about this more effectively?....
Thanks for any ideas!
~ Julie
Reply 1 of 1, by leileilol
You use DOSBox, you keep your CD mounted (use a CD image), and you play it.
Read the readme, the guides.
