Best ms-dos game music.
First post, by dosquest
Hi, I have a computer with an sb16 and I was wondering what games do you suggest I play to get the full advantage of the sb, I'm also looking for the fun factor also.
Reply 2 of 46, by dosquest
Well, I mean what games on your top list have really supurb music.
Reply 3 of 46, by rfnagel
If you're refering to OPL FM synthesis:
The oldie "Cybersphere" without a doubt -> http://www.classicdosgames.com/game/Cybersphere.html . Pretty amazing stuff what that guy did with the OPL3 😀
Another good one is Brix -> http://www.classicdosgames.com/game/Brix.html (as well as Brix 2 Deluxe). Those two used the old Creative Labs' "CMF" (Creative Music Format) for their FM music.
Lastly, the old arcade shooter Tyrian -> http://www.classicdosgames.com/game/Tyrian_2000.html . Although it sounds MUCH better in GM mode, it's music sounds rather neat in SBPro mode.
(edit) Heh, and "Jill of the Jungle" as well -> http://www.classicdosgames.com/game/Jill_of_the_Jungle.html ... like Brix above, all CMF music files. "OMINOUS.CMF" is especially neat sounding 😀
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 4 of 46, by dosquest
Thanks, I'll try those. I recently picked up a cheap pair of speakers to test sound cards with.
Reply 5 of 46, by leileilol
Adlib Tracker 2 is a sure bet. It ships with tons of modules, but it's not fun unless you're a YMF262-obsessed musician then the fun factor's through the roof.
Reply 6 of 46, by dosquest
Now, keep in mind I have an sb16
Reply 7 of 46, by leileilol
Yes, and Sb16 is adlib compatible.
What SB16 do you have? Hope it's not the later ViBRA budget variants
Reply 8 of 46, by dosquest
I don't think so, I will check tomorrow, maybe post pics also.
Reply 9 of 46, by leileilol
well if you want to find out easy, play Doom, e2m2 or doom2 map01
Reply 10 of 46, by eL_PuSHeR
[Thread moved to Milliways Secton]
Reply 11 of 46, by Malik
Appreciation of music is really subjective.
Have a look at the following topic too :
Technically impressive FM synth music ( Technically impressive FM synth music)
Reply 12 of 46, by rfnagel
Malik wrote:
Have a look at the following topic too : Technically impressive FM synth music ( Technically impressive FM synth music)
Hehe, that's where I first learned about "CyberSphere" 😀
Rich ¥Weeds¥ Nagel
Reply 13 of 46, by rfnagel
P.S. You can play CMF files with the files in the attached ZIP 😀
First run "SBFMDRV.COM" to load the Creative Labs CMF FM driver, then:
PLAYCMF.EXE filename.CMF
(edit) Just forgot another that used CMF format music files, "Traffic Department 2192" -> http://www.classicdosgames.com/game/Traffic_D … tment_2192.html , although I never really cared for the game's music that much.
Rich ¥Weeds¥ Nagel
Reply 14 of 46, by Jorpho
Heh. I remember Brix for having astonishingly high-quality PC speaker sound effects. (Or maybe they just seemed better than they were when paired with the graphics.)
Reply 15 of 46, by rfnagel
Yep, Brix (and Brix 2 Deluxe) had some pretty nice sounding PC speaker sound effects, as far as PC speaker sound effects go 😀
(edit) P.S. ¥Weeds¥ trivia(l)/historical tidbit:
Brix 1 and 2 was my *second* reason for eventually discovering DOSBox (the first being DOOM), after builidng up my current Windows XP rig 😀
Rich ¥Weeds¥ Nagel
Reply 16 of 46, by Gemini000
Megarace has a few catchy synth tunes and can be obtained on gog.com along with the second Megarace game for $6.
If you want a variety, Doom, Doom 2, Ken's Labyrinth, Rise of The Triad and the first Descent game (not the second one) all have HUGE varieties of MIDI tunes, many of which sound OK over FM synth.
Or if you want to hear something technically impressive, Earthsiege uses a combination of synth AND digitized sounds for its music, with its setup program's tune really stealing the show.
And then of course there's Cybersphere and Cyberpshere Plus which are nothing but synth music and sound and are perhaps the best examples of what can be done with the OPL3 chipset present on most Sound Blaster cards.
However, if you're trying to compare the difference between a Sound Blaster 16 and an earlier card like a Sound Blaster 2.0, the only major difference is bit-depth, as the Sound Blaster 16 can actually output 16-bit sound (hence the name) allowing for more accurate sound production in games which recorded their sound effects at a 16-bit level. TBH, noticing the difference between 8-bit and 16-bit sound is rather hard.
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
Reply 17 of 46, by rfnagel
Man! There ya go again, Gemini000... MAKING/FORCING me to go digging through all of this mess of CDROMs/floppies so's I can hear the Earthsiege tune 🤣! 😀
(edit) Installed Earthsiege from my CDROM... I totally forgot how cool that soundtrack was; with the synth and digital combo 😀 I had forgotten that they used digital sounds for the percussion, and synth for the rest of the instruments in the MIDI soundtrack.
Hmmm... that kick and snare is especially nice... I'm thinking "SoundFont Conversion" <grin> 😀
Rich ¥Weeds¥ Nagel
Reply 19 of 46, by leileilol
You'll notice that about the other Epic Megagames too in Kiloblaster, Xargon, Jill of the Jungle, Brix, Solar Winds, but strangely, NOT Overkill. (That uses some custom adlib raw data format of its own also used in Lemmings)
I think Heros (sic) might use CMF too, not sure.
