First post, by dada
Does anybody know if it's possible to select a custom resolution in Windows 95?
I managed to install drivers for my FW900 and S3 Virge 4MB but Windows is still limited to the same 4:3 resolutions despite the fact that the monitor is 16:10. I'd like to somehow get a widescreen resolution going.
If this is impossible with the S3 Virge (hal9000 just mentioned on IRC that the Trio 2D core, used by the S3 Virge, probably doesn't allow for this) does anyone know of a video card model that could work? Might buy it from eBay because it would be nice to get this working.
Reply 1 of 17, by MrKsoft
There are some notes on this page about running a Voodoo5 in widescreen resolutions like 1440x900 and 1680x1050 on Windows 95, which seems to require manually programming them into the registry. I don't really know much about how this works, but it may be possible to find the timings needed for other cards to run in custom resolutions. (I would assume the given ones on the page only work with the Voodoo5, but it's at least something to start off of)
http://toastytech.com/guis/miscb.html
edit: Found another page linked a little later that has VESA timings for various resolutions-- they may be usable: http://tinyvga.com/vga-timing
Reply 2 of 17, by Old Thrashbarg
Dunno about the Virge specifically, but on a lot of video cards, it was possible to add custom resolutions in the registry, or to a section of the driver INF file (and then reinstall the driver with the modded INF).
Reply 6 of 17, by dada
F2bnp wrote:
Maybe you need to install drivers for the monitor. Even generic ones.
I did, unfortunately the Sony FW900 official drivers didn't work.
Decided to put this on the back burner for now until I get Ethernet working. 😀
sliderider wrote:
Intergraph 28hd96. 28 inch widescreen 1920x1080 CRT.
Is that really a monitor, and not a TV? It looks spectacular. Ran a search for it but it seems to be extremely rare. Which isn't surprising.
Reply 7 of 17, by sliderider
dada wrote:
I did, unfortunately the Sony FW900 official drivers didn't work. […]
Yes, it's for real. I almost bought one once but unfortunately you can only ship them by freight and freight carriers will only deliver someplace that has a loading a dock otherwise you have to pick it up at the nearest freight terminal and I don't have one nearby.
No, it's not a TV. They were actually made before 1080P televisions were even around. They date back to around 1999, maybe a little earlier.
Reply 8 of 17, by Tetrium
Widescreen CRT...never knew those existed 🤣. Must've been quite a task to engineer
My retro rigs (old topic)
Report spammers here!
Reply 10 of 17, by Old Thrashbarg
I'd rather have this one
{snip}
Meh. 16:9, 1920x1080@85hz max, and looks like a shadow-mask screen. Compare that to the Sony, which is 16:10, 2304x1440@80hz max, and is a Trinitron.
I'd snap up an FW900 in a heartbeat if I ever found one for sale, but TBQH I'd hesitate to take that Intergraph monitor even if it were given to me.
Reply 12 of 17, by TheMAN
16:9 is quite useless in computing... there's no enough vertical resolution to get any productivity out of it... 16:9 is a marketing ploy, not any sort of practicality
16:10 is the way to go, but it is also going the way of the dinosaur, otherwise 4:3 is way more useful
Reply 13 of 17, by sliderider
How do you figure that? 1920 x 1080 is far more useful than say 1680 x 1050 or 1600 x 1200. And the Intergraph was a high end professional monitor so obviously someone was being productive with them. 1920 x 1080 is the same as 1080p, so even if you're crating Blu Ray quality videos or 1080p television programs you don't need more resolution that. Under what circumstance is 1920 x 1080 useless?
Reply 14 of 17, by bushwack
That monitor that everyone is going wowsers over can run 1920x1200 @ 85hz, that's the point he's trying to make. I too would prefer the extra vertical resolution of the Sony.
Reply 15 of 17, by SquallStrife
TheMAN wrote:
16:9 is quite useless in computing... there's no enough vertical resolution to get any productivity out of it... 16:9 is a marketing ploy, not any sort of practicalityl
Oh dear, funniest thing I've heard today!
Reply 16 of 17, by Pippy P. Poopypants
Works perfectly for Asians, after all, we see in ultra-widescreen.
GUIs and reviews of other random stuff
Вфхуи ZoPиЕ m
СФИР Et. SEPOHЖ
Chebzon фt Ymeztoix © 1959 zem
Reply 17 of 17, by sliderider
I thought you saw in letterbox. 😳
Incidentally, how do you set custom screen resolutions in the registry and can you set the color depth, too?
