First post, by sliderider
http://www.adek.com/ATX-motherboards.html
Reply 2 of 14, by Dant
And typically lack features necessary to our purposes like DMA.
Reply 3 of 14, by jmrydholm
No DMA *and* a rip off??
*Grand Moff Tarkin voice* "She lied. She LIED to us!!"
Edit: aren't there any PCI slot to ISA options? I saw a few online for the cost of a decent motherboard. Would it be possible to utilize another PSU combined with a backplane and host card? Because you know, uhhhuhuhuh That would be cool! uhhhuhuhuhuh
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
Reply 4 of 14, by sliderider
Yeah for like $4000 dollars you can buy an ISA breakout box with a PCI controller card. You get something like 10 ISA slots in a box about the size of an IBM 5150, oh and it requires it's own power supply as well.
Reply 5 of 14, by SavantStrike
I've seen bridges for around 500-600, but I can't remember where and don't know about their usefulness.
The breakout box really is the way to go, but it's pricey... I couldn't ever justify it, that's for sure.
Reply 6 of 14, by Jorpho
There is also an ISA-to-USB device somewhere out there, but naturally it's not a plug-and-play solution and you'd probably have to do a lot of coding to get it to do anything practical.
Remember the P4 board with a vacuum tube?
Reply 7 of 14, by jmrydholm
I think I've seen that ISA-to-USB device before too. The vendor stated that they have absolutely *no software* to control it and that the end-user would have to code their own solution. Sounds like a true geek's challenge! Wish I could code...I'd contribute.
Reply 8 of 14, by megatron-uk
The most modern board with full ISA support (eg NMI, ISA DMA) appears to be the Ibase MB800 series:
http://www.ibase.com.tw/2009/MB800V.html
The MB800H as I and several others use also have an AGP 4X slot.
I've not seen anything with Pentium-M, Core2/Core2Quad cpu options that has a fully working ISA subsystem.
https://www.target-earth.net
Reply 9 of 14, by sliderider
megatron-uk wrote:
The most modern board with full ISA support (eg NMI, ISA DMA) appears to be the Ibase MB800 series: http://www.ibase.com.tw/2009 […]
Intel 845 chipset? Doesn't that require RDRAM? Yuck.
Reply 10 of 14, by SavantStrike
That's the 850. And not quite yuck. It held the memory bandwidth performance crown until granite bay with dual channel DDR. Admittedly, the ram cost a fortune.
Reply 11 of 14, by jmrydholm
So if I wear a Devo suit and start playing subliminal industrial trance at the ebay sellers, will the market value lower? 🤣
That is a nice motherboard though, I'd like to put it on the game grid and see what it's made of. 😁 *MCP voice*
Reply 12 of 14, by bauer5152
I also think so.
Watch Zookeeper Online Free
Reply 13 of 14, by megatron-uk
No. It's DDR.
Reply 14 of 14, by schlang
I would buy it. price does not matter 😀
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
