First post, by retro games 100
Edit: Solved! Please see h-a-l-9000's advice below this post. 😀
I am testing a 286 mobo. On this mobo there is a model code, and it reads: BI-025C HT12 286. I have found a diagram of this mobo on Stason. It is here. However, the jumper label numbers on this webpage do not match up with the jumper label numbers on the mainboard. For example, a jumper on that Stason webpage will say "JP7", but on my board it will be "JP4". The jumpers on the diagram, and on my board are in the same location, it's just that the jumper number labels are not the same.
Unfortunately, the mainboard battery was leaking. I can see acid on the external battery header pins, and also inside the keyboard chip socket. I removed the battery. It was very easy to remove the battery, because it just "fell off" as I pushed it. I tried attaching an external battery to the externa battery header pins, but these pins have got "blue fur" on them, because of the battery acid. So, I decided to attach the external battery to the cleaner looking solder spots on the underside of the mainboard. I attached the external battery wires to the external battery header pin solder spots.
When I switch on power, I always get the BIOS POST error message of "CMOS INOPERATIONAL. SYSTEM HALTED." Is this because of a battery related problem? I have tried 4 different memory configurations. I got these memory configurations from that Stason webpage. Currently, I have no SIMMs installed, and I only have the mainboard's BANK 0 memory chips installed.
Any ideas please people? Thanks a lot for any help! 😀 BTW, I am testing this mainboard with just a 16-bit VGA card. I have not attached any other piece of hardware to mainboard, such as an IO controller, etc.
Reply 1 of 22, by Mau1wurf1977
Have you got one of these ISA POST testing cards? You might want to get one of these. They also come as PCI version.
My YouTube channel
Reply 2 of 22, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
First try to re-seat the HD146818 chip (when pulling it check if some pins are corroded). If that doesn't work try one from another board (a DS1287 works too iirc). If it still doesn't work some traces may have been damaged by the battery. You can try to clean it then.
1+1=10
Reply 3 of 22, by retro games 100
h-a-l-9000, you are a super star. A retro ninja. Thanks! 😁 I replaced the HD146818 chip with a Dallas RTC code DS12887, and I no longer see that BIOS POST error message. Instead, I am able to navigate the BIOS set up area. Awesome. I will mess about with this board, and see what it can do. Please note that I tried to reseat the HD146818 chip, but that didn't solve this problem. Perhaps the chip has died? Perhaps the legs are corroded, although they looked OK.
Mau1wurf1977, I do have a BIOS POST test analyzer card. Somewhere. 😉 😦
Reply 7 of 22, by Markk
Exactly! I've got just one spare board to play with, but it's like that.... Is the 286-20 so rare? I didn't know. Last year I won an ebay auction having 4 386dx/16, one 386dx-25, and a Harris 286-20 for about 15-20$.
Reply 8 of 22, by sliderider
It isn't as much the CPU's, as it is getting a 286 motherboard that will run at 20mhz where you're going to spend the most money. The CPU's are rare, but the motherboards are even rarer.
Reply 9 of 22, by retro games 100
Very unfortunately, my luck with this board has taken a "wrong turning". 😉 I decided to continue testing the board, to see what it could do. Very quickly, I realised that something was wrong. After successfully entering some basic set up details inside the BIOS set up area, the BIOS POST memory count freezes. Usually, it freezes on 64Kb. Sometimes it will get higher, and then freeze. I have tried various memory configurations on the mobo. For example - I have removed all of the little memory chips on the board, and installed four 1MB SIMMs. This should work, but it doesn't help with this current problem.
Very luckily, I spotted an auction on ebay for a used HD146818 chip. It's identical to the "clock chip" that I removed, and replaced with a Dallas RTC. BTW, I have also tried 2 Dallas RTCs, and one ODIN RTC. All 3 RTCs do not allow me to boot up this mobo successfully. There is an unfortunate side effect with this current problem that I having with the mobo. When the memory count freezes (as seen in the photo below), I cannot get back in to the BIOS set up area. I am completely locked out of it. The only way to proceed, is to remove the Dallas RTC unit, and replace it with another!
Just once, out of about a dozen boot up attempts, the boot up sequence worked, and DOS 6 was booting OK from a floppy diskette in drive A:. But it froze when it looked for the CD-ROM drive, but this may be because I do not have any optical drive present. However, I would expect the boot up sequence to skip past this stage. Perhaps a 286 can't cope with DOS looking for a CD-ROM during its boot up sequence?
Reply 10 of 22, by Markk
I thought that If I had a fairly late 286 board, with a HT chipset like that, which supports a 16MHz cpu, would be fine at 20MHz by changing the crystal. I have an identical board as the one in my 286 pc, but I was thinking I should avoid modifying anything on that, and just keep it for spare. The CPU can be changed, but the crystal is soldered on the board. Perhaps it's not a big deal to desolder it, and attach a socket for a crystal.
RG100, if it worked fine before you changed something in the BIOS setup, then you should remove the dallas chip and the batteries. Leave it sometime, and then put them back on. It should then have it's original settings.
edit:
I think my 386 used to do that also. If you manage to boot again, press F8 when it says Starting MS-Dos ....., and avoid loading the cd-rom driver.
Reply 11 of 22, by Tetrium
Just to be sure, the battery you removed was rated for the same voltage as the batteries you're using now?
I had a similar issue with another (much more modern) board once. It would either successfully boot, or it would freeze during the RAM count. Sometimes it even froze hard when inside the BIOS itself.
A BIOS update didn't fix this, not did swapping memory around.
Another strange thing was that I was totally unable to load any kind of Windows onto that thing, it would generate somekind of error, kinda as if the system was sticking up it's middle finger or something 😜
What was especially weird with this board is, I could move an existing 9x installation to it and it would work perfectly fine?? At least afaicr.
Never figured out what it's problem was, but I ended up redesignating that board for testing CPU's -_-
My retro rigs (old topic)
Report spammers here!
Reply 12 of 22, by Markk
Oh, that's right! Check the voltage of the batteries. On my 286, on which the board is similar, 2 AAs are enough. I have them for over a year up to now, and they hold the date/time very accurately.
Reply 13 of 22, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
With the DS12887 he plugged in batteries are not required at all (it is included in the DS12887). Somehow I doubt the freeze has to do with the RTC chip. But then maybe it is too modern for the BIOS to handle.
1+1=10
Reply 14 of 22, by retro games 100
Unfortunately, I am not having any success with the Dallas RTC. I have experimented with various mobo jumper settings, just in case something is incorrectly configured on the mobo, but this hasn't fixed the problem.
As I have ordered a replacement HD146818 chip, I will have to go back to using an external battery. I spotted an auction on ebay for various sized battery holders: 2, 3, and 4 AA battery holder packs. My current 3 AA battery holder is not very good, so I'll buy this item, and then try the 2 AA battery holder pack. Thanks.
Reply 15 of 22, by Tetrium
Care to post or PM a link? I'm still in the market for purchasing a couple if I can find them for +++ cheap 😁
Reply 17 of 22, by Tetrium
If you type in
aa battery holder
in to ebay, hundreds of results are returned.
Doh!!
It's only after reading your post that I remembered I asked you the exact same thing about a month ago! 😅
Reply 18 of 22, by retro games 100
If you type in
aa battery holder
Doh!!
It was several months ago, I think. 🤣
Reply 19 of 22, by Markk
I've just modified my spare 286 board! It had originally a Siemens 286/16.
I removed the cpu, and installed my Harris 20MHz one. It worked of course, but it still run at 16MHz.
Then I took my soldering iron and removed the 32MHz crystal. I broke one of it's four legs, but never mind. I put a crystal socket I had from a broken board, and then tried a 40MHz crystal. It works fine, and it's counting the memory much faster.
In general it feels a lot faster than before. Then I tried to overclock it, by placing a 50MHz crystal, but I couldn't achieve that for more than a couple of seconds...
Now, what's really cool... The cpu! The other 12-16MHz 286s from intel-siemens-amd I've seen, get really hot. I can't touch them after of 5minuts of use. That 20MHz Harris, is a lot cooler. It reminds me a 386sx-25 I have.
I also tried an 8MHz Intel 287 I've got. It also runs at 10MHz, but at 12 the system hangs. This one, gets extremely hot, though. Even at the stock speed of 8MHz....
