First post, by lucky7456969
Any web sites that I can look?
Or books?
Thanks
Jack
Reply 1 of 12, by Sol_HSA
Making a game, or hacking one?
http://iki.fi/sol - my schtuphh
Reply 2 of 12, by lucky7456969
pure learning 😀
Reply 3 of 12, by Davros
many people have started with the quake source code (by making small mods at first)
although I wouldn't recommend it to someone with no experience of programming
Reply 4 of 12, by leileilol
quake's source code doesn't compile for dos though
Reply 5 of 12, by lucky7456969
Hi,
What are the general steps to debug a compiled game executable? By looking at the location A000:0000? just want to learn how to fix certain games that have problems with dosbox...
Thanks
Jack
Reply 6 of 12, by RoyBatty
fire up turbo debugger or softice and start having a go =]
Reply 7 of 12, by lucky7456969
Looking at the whole lot of assembly seems to be overwhelming. Do all people who debug have to spend a lot of time doing that? or there is an easier way to analyse the output?
Thanks
Jack
Reply 8 of 12, by Davros
there are one or 2 decompilers that decompile to C
but write a very simple program decompile it and stare in awe as the result bears no resemblance to your source code 😁
ps: list of games with sourcecode (a lot of them dos)
http://www.classicdosgames.com/misc/source.html
Reply 9 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
Thanks
Jack
yes, reading assembly is the most common when debugging dos games.
Water flows down the stream
Reply 10 of 12, by Zup
Also, keep in mind that people debugging games usually knows what are they looking for. If your program doesn't save data, you'll start searching for open file or write DOS calls; if your program keeps complaining about serial numbers, you could start looking when the error message is triggered... and so on.
If you have written the program, usually you'll keep a symbol table of the executable, so it is easy to trace through the code. Also, most compilers have their own debuggers so it is very easy to trace your own programs.
And, as Qbix said, if you've got no access to source code or symbols, everything is translated to machine code, so reading assembly is unavoidable.
I'm selling some stuff!
Reply 11 of 12, by Tetrium
Thanks
Jack
Doing anything that has to do with code (including doing mods for games) involves investing a lot of time!
If doing so, consider it your one and only hobby for weeks on end 😜
(have modded games myself for years off and on so I know what I'm speaking of 😉 ).
My retro rigs (old topic)
Report spammers here!
Reply 12 of 12, by RoyBatty
Knowing assembly and getting used to staring at it for hours on end. That's required if you want to do just about any kind of modification to a game. After many hours of doing it, you'll start to recognize certain functions and repeated routines. Years of doing it will allow you to almost read the code like a book. It just takes desire, time, devotion and lots of references materials.
