Won't even start up
First post, by varkarrus
It gets to MIDI: Opened device:win32
and just stays there.
forever.
Reply 1 of 16, by wd
Rank DOSBox Author
DOSBox Author
Works fine here.
Reply 2 of 16, by varkarrus
wait wait wait wait. What?
no no this is a problem I'M having.
And I don't know how to fix it.
Reply 3 of 16, by wd
Rank DOSBox Author
DOSBox Author
I tried to reproduce your problem, but it works plain fine here.
Reply 4 of 16, by varkarrus
I am confused.
Pretty much, I didn't mess with the settings at all. I've installed 2 different copies of DosBox on this computer (uninstalling the other first, of course).
It gets to Opening MIDI
then I can't type anything or do anything at all in either window.
Reply 5 of 16, by wd
Rank DOSBox Author
DOSBox Author
So you are absolutely sure that the up-to-now only relevant information (you installed "it" on 2 nobody-knows-how-they-look-like PCs)
is enough to give you any hints? Do you expect some "please use the secret do-not-crash-on-startup switch" reply?
Reply 6 of 16, by varkarrus
yeah kinda. I'm not too technoligically savvy?
If it helps, it's a laptop running windows 7 with an intel core inside and I have working MIDI, I know that.
It was DOXBox. The latest version. I also tried the portable version.
I cannot find the older versions in case those work.
I was kinda more hoping that someone would have had this problem before.
Or that you'd know what it was getting frozen on so I could investigate further.
Reply 8 of 16, by varkarrus
All of them?
Because I had HUGE PROBLEMS with my sound card until I rolled it back. And then windows downloaded an update and then I had to reformat my computer because it froze everything. Ah well. I'll give it a go.
Thanks for being helpful.
Reply 10 of 16, by wd
Rank DOSBox Author
DOSBox Author
At least we know you're using windows now, and installed some sort of new version of dosbox.
Reply 11 of 16, by varkarrus
well it's installing a whole whackadoo of updates right now. Let's see what happens.
Reply 13 of 16, by varkarrus
Okay I went and fixed it on my own.
Haha.
All I had to do was change the drawing type to OpenGL
I really, really, REALLY wish you mentioned that this could be a problem. Then I wouldn't have had to wait while it downloaded a bajillion updates that I don't want.
Reply 14 of 16, by eL_PuSHeR
Anyway it doesn't hurt to have everything up to date, doesn't it?
Glad to hear you sorted out your issue...
Reply 15 of 16, by wd
Rank DOSBox Author
DOSBox Author
So that would be a problem with your graphics card/drivers.
Reply 16 of 16, by varkarrus
Actually, having everything up to date was what blew up my computer last time.
