First post, by DOSGuy
I hate to create a new thread, but the most appropriate thread to bump (Windows 95 in DOSBox with 256 Colors, Sound, and CD-ROM support) was locked.
I tried to get Windows 95 to work in DOSBox for several years without success. Installation in DOSBox would always fail, and Win95 images created in other emulators would never load. Those who claimed to be running Windows 95 in DOSBox seemed to indicate that only Windows 95A could run in DOSBox, whereas I had only Windows 95B and C.
Today, with great joy, I acquired the original Windows 95 installation CD. Installation in DOSBox still fails at the very end of the installation process, but I was able to install it in Bochs, and I was able to boot the image in DOSBox by adding the line "device emm386.exe frame=e000" in config.sys, per wd's advice. Success! Years of effort have finally been rewarded!
I have no trouble installing SoundBlaster 16 sound in DOSBox, but video is limited to 16 colors. I have tried installing the various S3 drivers that come with Windows 95, as well as legacy drivers from S3's website, without success. I also tried to install Scitech Display Driver 7.0.0.340 Beta, but it dies with an illegal operation message.
Has anyone successfully managed to get 256 or more colors in Windows 95 in DOSBox?
Finally, let me say that I come in peace. I understand that DOSBox is for playing DOS games, not running Windows 95. I also don't expect the devs to support Windows 95. I'm just politely, respectfully asking for help.
"Today entirely the maniac there is no excuse with the article." Get free BeOS, DOS, OS/2, and Windows games at RGB Classic Games
Reply 1 of 36, by leileilol
Using a 1996-ish dated S3 Trio 64v+ driver may work. Also, use machine=pentium_slow
DON'T INSTALL DIRECTX YOU'LL RUIN EVERYTHING
long live PCem
FUCK "AI"
Reply 3 of 36, by DOSGuy
Victory! w950109b.zip was the missing piece of the puzzle. Three cheers for DosFreak!
Reply 4 of 36, by DOSGuy
DirectX 5 installs and works great!
Old DirectX games just don't work under Windows 7 x64, even in Compatibility Mode, and Windows 95 under VirtualBox and VirtualPC is flaky at best. DOSBox is officially the best way to play old Windows 95 games!
Reply 5 of 36, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Nope, officially Dosbox is NOT intended for Windows 9x (even though you are right, it's a working mostly great 😉)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 36, by Jorpho
Huh?
Reply 7 of 36, by sliderider
How do you get Windows to work in DOSBox? Wouldn't you have to reinstall it every time you restarted?
Reply 8 of 36, by Dominus
DOSBox Moderator
Huh? There are some locked guides on this on the forum.
Reply 9 of 36, by DOSGuy
I meant unofficially "officially". 😜
And yes, there are many guides on this forum, and I'll be adding a guide to RGB Classic Games as well, so there's no need to go over the procedure in this thread.
@sliderider: No, because you save the installation on a hard drive image.
@Jorpho: All Sega PC games are unplayable on Windows NT-based operating systems (although there is a patch for Sonic CD). Jedi Knight: Dark Forces II is horrible under Windows 7 x64 on my computer, and completely unplayable in Windows XP Mode because the mouse goes crazy (impossible to aim). Klingon Honor Guard doesn't work with crap for me in Windows 7 either, although I can run it in Windows XP Mode. It's just a pain to get many older DirectX games to work in modern Windows. You pretty much need Windows 95/98/Me to play a lot of those games.
Reply 10 of 36, by Jorpho
Yes, there are some specific games that do not run under Windows 7, but the reasons are varied and complex and often have nothing to do with the fact that they use an older version of DirectX. There are also plenty of other older DirectX games that do cooperate with Windows 7.
And I'm sure there's got to be a patch of some sort for Dark Forces II. They still sell it on Steam, after all.
As for Sega's PC games, they were so varied that I kind of doubt you've tried them all. Offhand, it looks like there's also a patch for the Windows version of Ecco the Dolphin at http://web8.orcaserver.de/ecco/downloads/programs/index.php .
Reply 11 of 36, by DOSGuy
There may very well be a patch for all of them, but a patch is unnecessary if you just use Windows 95. Windows 95 runs too slowly for me under Bochs, and I've never been happy with the experience under VirtualBox and Virtual PC. The experience of running Windows 95 games under DOSBox is the same as the experience of running DOS or Windows 3.1 games under DOSBox. I can also easily record my gameplay in DOSBox's lossless ZMBV format, which I use to find the screenshots that I use in my game reviews.
To each his own, of course, but for me, running Windows 95 under DOSBox is the perfect way to play early Win9x games.
Reply 12 of 36, by Jorpho
By the way, you're not using one of those builds with Voodoo emulation, are you? Or when you say "DirectX 5 installs and works great", do you mean everything except Direct3D?
Reply 13 of 36, by DOSGuy
I'm just using standard DOSBox 0.74 at the moment. Everything I've tried to run has worked so far, but I'll remember your warning about Direct3D if anything doesn't work in the future. Thanks for the heads up.
Reply 14 of 36, by mr_bigmouth_502
It would actually be kinda cool if there was a custom build of DosBox designed specifically for running Win95.
Just sayin'. 🤣
Reply 15 of 36, by Jorpho
Someone would probably have to fork the code and make it himself. As for actually improving its stability and such forth, it has been repeatedly asserted that things are a hideous, nightmarish mess at that level.
Reply 16 of 36, by wd
Rank DOSBox Author
DOSBox Author
There's simply no point, if you address compatibility issues you'll be below bochs level so why not use bochs in the first place or some virtualizer.
Reply 17 of 36, by mr_bigmouth_502
You have a valid point, but I haven't seen any virtualization apps that work as well for playing older games as DosBox, mainly because most of these virtualizers lack vital gaming-related features that are already a part of DosBox, such as on-the-fly speed control and decent soundcard emulation.
Reply 18 of 36, by Jorpho
Bochs has SB16 emulation. Have you tried Bochs lately?
...zuh? What does this have to do with Windows 95?
Reply 19 of 36, by wd
Rank DOSBox Author
DOSBox Author
Then ask them to add those.
