First post, by ratfink
I'm trying to get straight in my mind, which NT operating system versions will take advantage of and run properly on, multiple physical cpu and multiple-core cpu systems, and what the limits are. I have tried googling but it became so convoluted I am posting here in the hope someone may know.
I have [legitimate!] copies of the following OS's, and I have set out what I think the compatibility is:
NT 4.0 Workstation - seems to run on multiple-physical-cpu systems. I'm guessing it won't recognise multiple cores but then it probably won't run on any hardware that can take multi-core cpu's anyway. But how many physical cpu's can it use?
2000 Professional - runs on up to 2 physical cpu's but it's not clear whether it will run properly on dual-core cpu's. From what I can tell there is no official support although iirc it will recognise multiple cores [presumably up to 2]. I'm sure I ran it on a couple of dual core boxes and there were various crashes though at the time I attributed these to other factors. I wonder now if it was due to multi-core issues.
XP Home - seems like it doesn't recognise multiple physical cpu's but it will recognise multiple cores. But is it limited to 2 cores or can it take advantage of 4, 6 etc?
XP Professional 32-bit - recognises and uses up to 2 physical cpu's, and will recognise and use multiple cores. But what are the limits? Will it use all cores on a 4-core or 6-core cpu?
7 Professional 64-bit - recognises and uses multiple cpu cores, presumably unlimited. No idea if it supports multiple physical cpu's.
Why does it matter? Because one of our systems needs an upgrade and that might allow some reshuffling of hardware and os's, and the same sort of issue will recur for a few years yet.
