First post, by toxee
If so with what settings and dosbox build? This demo has a wicked pop rock track and I've been dying to listen to it but it doesn't run well in any build. Appreciate any help.
Reply 1 of 4, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Runs fine in 0.74 with default settings, AFAICT. What problem do you have with it? Saying "it doesn't run well" is a bit vague...
Reply 2 of 4, by megatron-uk
Wouldn't work in my 0.74 version with gus enabled (froze as soon as the bars at the top and bottom of the screen appear), once I turned it off (gus = false) it runs fine.
https://www.target-earth.net
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
GUS is disabled by default.
Reply 4 of 4, by toxee
Yeah it was running odd and the music was real slow even at max cycles. Instead of the dots spinning in a circle giving off the tunnel illusion, they just floated across the screen horizontally from left to right. I was using d-fend reloaded though, I ran it raw with Daum Cafe and it ran like a dream. Thanks for the help and info.
