ALT+LeftShift Issue
First post, by cranstantinople
I need to use the key command ALT+LeftShift for a dos program I'm trying to run however, the program doesn't respond to the command when I press the Key combination. Since ALT+LeftShift is used to switch keyboard languages, is that why the program is not accepting my command? It specifically has to be LeftShift.
Reply 1 of 1, by eL_PuSHeR
[Thread moved to DOSBox General Section]
