First post, by Paule
Paule
Offline
Hello DOSBox community!
I use DOSBox to run an old 16 bit compile/linker which crashes under Win32 environment for various reasons.
So far, it looks good. Just a few questions:
- Is there are way to return an error code from DOSBox _shell_ when exiting (EXIT)?
- Are there any IPC methods implemented like piping commands into DOSBox and returning output from DOSBox while it is running? Do I have to utilize files? (So far, I use -c flag on startup.)
Cheers,
Paule
