First post, by pewpewpew
- Oldbie
This one is new to me. Here's the only information I turned up:
Maximum PC feb 2004 - The Latest on the IBM 75GXP Lawsuit
"One issue never actually resolved in the documents is the actual cause
of the problem. Some of the problems stemmed from a bug in Windows 98
that created a false bad sector when the os shut down before the write
cache in the hard drive could be flushed."
link:
http://books.google.com/books?id=NwIAAAAAMBAJ … ved=0CBMQ6AEwAA
That sounds quite like what happened. I had a full lockup crash. On reboot I got the 'you did not shut down properly', followed by scandisk.
Scandisk marked a bunch of bad sectors, and fixed things by wiping out quite a number of files. Other utilities said the drive was fine - no bad sectors. Eventually I just repartitioned & refromatted, and ran scandisk again. This time got no bad sectors.
I do appreciate that crashes and delays are part of the sport with 98, but I'd like to avoid hitting this one again. Does anyone have insightful experience with false bad sectors? As said, I hadn't heard of it before.
FWIW, board is A7V133 rev1.04, and the drive is a secondary 80GB Maxtor 6Y080L0. It held the game that was booting when things crashed.
Crash was caused by me trying to close something else while the game splash screen was up. I should know better. Forgot I wasn't in Linux.
Aside from just not doing something so silly again, all I can think one could do is toggle 'Disable write-behind caching for all drives'. That's under System Properties > File System Properties > Troubleshooting
But I think that's really just for devs, not for normal use. It would carry a performance hit too.
