First post, by tallgal
Is there anything I need to add to the shortcut so the game will run without asking for the CD ROM? If I go through DOSBOX it's no problem, but when I try to put in the shortcut, there is a screen saying I must have the CD
Here's what I have in the shortcut target "C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe" -userconf"C:\DOSGAMES\newwar\WAR2.exe"
Thanks!
Reply 2 of 5, by tallgal
So would I add something to the shortcut text?
Reply 3 of 5, by bloodbat
Well, you could read the readme where all this is explained and is the recommended method, you could also make a .conf file for the game or you try dosbox.exe -c "mount <whateverdrivethegamexpects> <yourcd> -t cdrom" "C:\DOSGAMES\newwar\WAR2.exe" -userconf
Reply 4 of 5, by eL_PuSHeR
To the OP: I have deleted your other redundant post.
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
start menu (dosbox entry in program files)
