First post, by elior77
Hey !
I have an old special text editor, I would like to be able to open any file with this editor in dosbox...
I noticed that when I double click a file(lets call it prn) and associat it with dosbox, dosbox will mount the file path and try to run the file.
This is great but I need to open this file with this old special editor (that will run in win7 fullscreen only with dosbox
what dosbox does when double click on a prn file:
mount prn file path
try to run the prn file
what I would like to happen double click on a prn file:
mount prn file path
run a.exe filename.prn
a.exe = the editor
Thanks !
Reply 1 of 7, by wd
Rank DOSBox Author
DOSBox Author
Don't know why you're talking about dropbox, and why it's in the DEV forum. But you could start reading the DOSBOX readme of course.
Reply 2 of 7, by elior77
DOSBOX !! not dropbox 😀 sorry
After I tried google I found this place...
I read the readme - could not get it done.
can I get some help here ?
Thank you
Reply 3 of 7, by wd
Rank DOSBox Author
DOSBox Author
Don't know if it's possible at the moment (it's not how dosbox should be used).
Did you have a look at some of the dosbox frontends? They won't allow you to
double-click an arbitrary file type and run something in dosbox then, but if the
files are somehow associated (like 10 different files only) you may be better off
with a frontend than with what you currently have in mind.
Reply 4 of 7, by aqrit
associate the files type with a batch script that launches dosbox
lets say you want to use the dos version of pkunzip to unpack all your zip files (for some reason)
@echo off
start D:\programs\dosbox\dosbox.exe -c "mount x: d:\dosapps\pkzip " -c "mount y: %~dsp1 " -c x: -c "pkunzip.exe y:\%~snx1 "
I don't know how well long file names are handled...
Reply 5 of 7, by elior77
Thank you.
I dont understand...
"start D:\programs\dosbox\dosbox.exe"
will start dropbox
will mount pkzip path as x:
will mount %~dsp1(??) as y:
what is %~dsp1??
-c x:
will change dir to x:
will run pkunzip for y:\%~snx1??
what is y:\%~snx1??
i need *.prn files to be opened under dosbox with a.exe...
thank you
Reply 7 of 7, by elior77
aqrit wrote:
associate the files type with a batch script that launches dosbox […]
@echo off
IT WORKS !!! thank you very much !! 😀
