First post, by Padd
I've done extensive googling on this and it seems a few people are having the same problem but I was unable to find a solution.
With a bit of CPU throttling Theme Park runs fine, its just that sometimes when the resolution changes (end of year screen etc.) the mouse freezes in the centre of the screen and I have to restart the game to play.
I have tried various changes in the Dosbox conf file and cant seem to resolve it.
I have changed MACHINE to svga_et4000, svga_s3 and svga_nolfb
I have changed output to all of the available options and im not sure what else to try. Any suggestions would be great.
The only way it seems to run is if I keep it in low res mode so it doesnt change resolution when the end of year screen comes up , which is horrible and id rather not 😀
Regards
