First post, by jwt27
A friend of mine is building a DOS machine, he has a Fujitsu mainboard with 440ZX chipset and a PhoenixBIOS.
Now we tried to set up UMBPCI for UMB management, it sets up the UMBs fine in C800-DFFF but DMACHK shows that ISA-DMA doesn't work in that memory region. No problem we thought, just set up UMBPCI to use E000-EFFF but it seems that the system bios is shadowed there (wtf?), and there is no way to disable it in the BIOS setup.
Now my question is, do we need ISA-DMA? And what is it exactly, I suppose it means that ISA devices don't have DMA access in that region? The only ISA card he uses is a sound card which is PnP.
Reply 1 of 3, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
And the floppy drive.
As soon as any program tries to use this memory area for DMA transfer it will fail. Question is, can that be prevented...
1+1=10
Reply 2 of 3, by jwt27
If the floppy drive is on ISA, is it possible that the IDE controller uses the ISA bus too? We tried to copy some files from CD yesterday, and it crashed. CD drivers were loaded in UMB..
Reply 3 of 3, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
For a PentiumII chipset I'd expect it to use PCI DMA, but I'm not very familiar with inner IDE DMA workings. You could set the drive to PIO in the BIOS to check.
1+1=10
