First post, by ACSKJP
I have 3 questions I'm hoping some people with more experience can answer.
For users of ATX power supplies in AT systems:
The ATX to AT converter cables have only 2 leads to the power switch, whereas the old power switches on AT systems have a on/off switch, or push-on push-off button with 4 leads. I want to keep the standard AT button, but I was wondering if, and how I can get it to work with the ATX to AT cables.
Additionally, I'm curious as to how much of a deviation is acceptable in the voltage range of AT power supplies. Some of the power supplies I have might have -8.42v on the -12v lead, or 3.14v on the 5v lead, etc. Where should I draw the line on what is safe/okay for the system? (this is one of the reason I'm considering trying an ATX power supply with the ATX to AT adapter cable)
Lastly, I heard many ATX power supplies don't have -5v leads. Is this a problem? If it's necessary in some situtations, what would those be?
Thanks!
