bios int 15h/ah=89h
First post, by Goplat
The dosbox implementation of the int 15h/ah=89h function in the BIOS is a bit off: it doesn't disable IRQs on the PIC, and (more importantly) it jumps to CX when it should just get the return address off the stack. Patch:
--- src\ints\bios.bak	Mon May 10 10:43:54 2010
+++ src\ints\bios.cpp Fri Sep 30 21:28:19 2011
@@ -700,8 +700,8 @@
break;
case 0x89: /* SYSTEM - SWITCH TO PROTECTED MODE */
- IO_Write(0x20,0x10);IO_Write(0x21,reg_bh);IO_Write(0x21,0);
- IO_Write(0xA0,0x10);IO_Write(0xA1,reg_bl);IO_Write(0xA1,0);
+ IO_Write(0x20,0x10);IO_Write(0x21,reg_bh);IO_Write(0x21,0);IO_Write(0x21,0xFF);
+ IO_Write(0xA0,0x10);IO_Write(0xA1,reg_bl);IO_Write(0xA1,0);IO_Write(0xA1,0xFF);
MEM_A20_Enable(true);
PhysPt table=SegPhys(es)+reg_si;
CPU_LGDT(mem_readw(table+0x8),mem_readd(table+0x8+0x2) & 0xFFFFFF);
@@ -710,10 +710,11 @@
CPU_SetSegGeneral(ds,0x18);
CPU_SetSegGeneral(es,0x20);
CPU_SetSegGeneral(ss,0x28);
+ Bitu ret = mem_readw(SegPhys(ss)+reg_sp);
reg_sp+=6; //Clear stack of interrupt frame
CPU_SetFlags(0,FMASK_ALL);
reg_ax=0;
- CPU_JMP(false,0x30,reg_cx,0);
+ CPU_JMP(false,0x30,ret,0);
break;
case 0x90: /* OS HOOK - DEVICE BUSY */
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
do you have an example game that uses/fixes this ?
This code was added for one game, although I have to look in the archives if I still have it somewhere.
Water flows down the stream
