dosbox fullscreen issue
First post, by critzen
This is really wierd because it seems like I used dosbox on the exact same computer I have now a year ago or so, but now that my periodic interest in playing dos games from my childhood has been rekindled I've found that, for whatever reason, I just can't get dosbox to run smoothly on my pc. When I try to fullscreen it everything just sort of stops, which is a problem I've never had. I'm running windows 7, any advice out there?
Reply 2 of 6, by critzen
cool, but what does that mean I should actually do?
Reply 4 of 6, by critzen
Thanks alot man. I'm just gonna have to do some studying up, the only way I've ever used dosbox or any other emulator for that matter has been by simply dragging the game file onto the emulator file, then typing in the command. I was also so young when dos was going on that I'm not familiar with the commands, but i'll figure it out.
Reply 5 of 6, by DosFreak
Modifying DOSBox.conf
Start->DOSBox 0.74->Options->DOSBox 0.74 Options
CTRL+F
output=
Change value.
Save the file.
UPDATE VIDEO DRIVERS
Press Windows KEY+PAUSE
Click Device Manager
Make a note of your video card
Go to video card manufacturer webpage
Download drivers
Install drivers.
Make your games work offline
Reply 6 of 6, by eL_PuSHeR
[Thread moved to DOSBox General Section]
