Win16/DOSBox?
First post, by Harry Potter
Is it worth the effort to install Windows 3.1 on DOSBox? Why or why not?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 1 of 17, by leileilol
Yes so you can play Ski Free and Klik & Play trainwrecks on Win64
long live PCem
FUCK "AI"
Reply 4 of 17, by Harry Potter
Basically for fun...right
Reply 5 of 17, by IIGS_User
Fun is bad.
Klimawandel.
Reply 6 of 17, by Harry Potter
I still have some old Win 3.1 aplications from when I played on a Win3.1-based 486SX33MHz PC, including After Dark, videos and some games. When I had that system, I eventually had to compress the hard drive. After that, it still lasted until a virus hit it. I'd really like to see some of this stuff in legacy/freeware. 😀 That's why I wanted to compress a DOSBox drive. What do you think?
Reply 7 of 17, by Qbix
Rank DOSBox Author
DOSBox Author
just create a larger harddrive inside dosbox.
Water flows down the stream
Reply 8 of 17, by Harry Potter
Never mind about the file compression thing: I'll just keep it in my own world for now. 🙁
Reply 9 of 17, by SKARDAVNELNATE
There are many games that work well in a Windows 3.1 DOSbox and some that don't. I think a better solution for Windows 3.1 is VPC 2007.
I find the colors make posts harder to read.
Reply 10 of 17, by MrKsoft
It works in DOSBox, but anything that needs SHARE.EXE (Office comes to mind as well as anything using Win32s) isn't going to work. I find that pretty disappointing because it's ALMOST the perfect replacement for an old PC. Virtual PC works, but the SB16 OPL emulation is absolutely atrocious (a real buzz killer since a lot of old Win3.x games use MIDI for music) and it's no use if your main computer is a Mac like in my case. Pretty much every emulator has a tradeoff-- nothing does a flawless emulation yet.
The OPL Archive - Preserving MS-DOS music in a unified format!
Reply 11 of 17, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yes, every emulator seems to have different goals 😉
And you are actually not correct, share does work in Dosbox IF you use a hard drive image and boot in dosbox from it. So if you REALLY need share then you are good. But does one really need those programs? I meanfor more than the one time "oh great it works"? For that one time you can also use the fakeshare from the win3.x guide.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 12 of 17, by wd
Rank DOSBox Author
DOSBox Author
Yeah and then have fun figuring out the random data corruption because fakeshare is only fake.
Reply 13 of 17, by Dominus
DOSBox Moderator
Yup, but it is good enough for those that want to run any of those office suites just to see them run or (and I'd count that as a real reason) if they want to open an old file with that. I seriously doibt anyone "really" wants to use the old share programs 😉
Reply 14 of 17, by Harry Potter
What else would be fun/useful?
Reply 15 of 17, by ADDiCT
Masturbation.
