First post, by totalizator
Hi everybody!
After I could not find any Covox to buy I've decided to build one myself. Here is the result: http://youtu.be/rKb1F-ApK3s and another video with more music http://youtu.be/x2iZFVoOq68.
Cheers!
Covox (Stereo-On-1) LPT Stereo DAC - home made sound card by drhabber, on Flickr
Reply 1 of 14, by MaxWar
Thats is very neat, and the thing sounds pretty good too, i am actually surprised, thumbs up!
Reply 3 of 14, by Stull
Perhaps the Doom E1M1 music? 😉
Reply 4 of 14, by MaxWar
That would have been cool, but the Thing cannot play midi unfortunately 😜
Reply 5 of 14, by GXL750
I'm surprised at the way it sounds; quite nice. I would have expected a Covox to sound more or less like a Gameboy.
Where are the mod files from?
Reply 6 of 14, by totalizator
The links to download MOD files are in the video's description.
There is not many games to play with Covox and you can find gameplays from some of them on YouTube already (Pinball Fantasies, Wolf 3D).
Reply 7 of 14, by Robin4
Make more and put them on ebay!!
Reply 8 of 14, by Sol_HSA
Well.. covox /speech thing is "just" a DAC bolted into the printer port, if I remember correctly. In any case there's no synthesis, so it sounds like the samples that are played through it, not like a gameboy.. =) Didn't know they come in stereo variety though.
http://iki.fi/sol - my schtuphh
Reply 9 of 14, by Cyberdyne
Ok I have a question for Dosbox developers and Covox maker, how do you make Wolfenstein 3D detect it as Disney Sound Soure, can i connect LPT pin 10 constantly to GND sufficient. Or is the detection mechanism more clever?
Reply 10 of 14, by Cyberdyne
Come on dudes, you made dosbox Disney Sound Emulation, and you can not give me istructions, how to make my covox behave like a Disney!
Reply 11 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The Disney actually has a little FIFO buffer, a simple DAC isn't enough.
1+1=10
Reply 12 of 14, by Cyberdyne
That i know! But if you cheat your program to use Disney driver with Covoxer, the sound works, it only checks that the FIFO buffer is not full, and FIFO tells it to the computer by holding LPT pin10 low. If it goes high, then it does not send sound information. Am I right?
Reply 13 of 14, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Detection routines vary between games, but typically they check that the FIFO reports full after a certain amount of writes, so yes they are more clever. The DSS also generates the sampling rate (FIFO emptying), so even if you trick it into being detected it will not sound correct, depending on the routine used by the game.
You assume that we are always reading every post?
1+1=10
Reply 14 of 14, by matze79
Does Auto Detection work with this one ?
