DOSBOX OS Install Issue
First post, by kubba
Hiya
I'm trying to install an OS to a blank hard disk on my computer using DOSBOX 0.74, but I'm running into an issue. After I boot the disk images (via boot command), the install program can't find any hard disks to write to, even after I mounted the blank HD. Is there a way to mount an HD before or after a boot command that lets the install program recognize it?
I've looked over the guides and manual and couldn't find anything addressing my problem.
It sounds more like a job for Bochs or something, but I'm having problems with that, too.
Thanks.
