First post, by extent
I know I can get versions that I can run in dosbox, but I have copies of old games, eg text adventures, which are a zip containing nothing but a single ".dat" file. eg "zork.dat"... How do I get them to work, is it impossible? I thought I had downloaded a version made for another device, or the extension was wrong (for zork), but I found out that the single dat within the zip was identical to the dat from the official zork website. The zip was just missing the other files. The zips I have were from a website that had dos freeware a while back, to run on pc. I may be wrong, but one ubuntu website (4th post down on second link) seems to suggest that a single dat will run on a program called Frotz, from
http://www.inform-fiction.org/zmachine/dos.html
http://ubuntuforums.org/showthread.php?t=409331
Im assuming that the website I got the dos files from probably thought that the dat was all that was needed? Looking through some other dos software, I also have single file '.exe', '.sol', or '.com' extensions etc within zips.. so Im not really sure what is a legitimate file and what is not. I can usually get .exe files to run in dosbox (or by unzipping them and running them in dosbox games launcher) but am having trouble with the rest. Thanks for any help
