First post, by sidv88
I have tried Elder Scrolls: Redguard using dosbox with both the nglide and glidos wrappers. However, in both methods, I have encountered a problem--the redbook music stutters and restarts when the game is being played. In the in-game menu (journal), the music plays normally. But when actually playing the game, the music keeps restarting and playing the same note repeatedly. This happens when I try playing Redguard both using nglide and using glidos. Is there any way this can be fixed?
Reply 1 of 8, by wd
Rank DOSBox Author
DOSBox Author
How many postings do you want to clutter on the forums? Instead of that post ONE complete report.
Reply 2 of 8, by sidv88
sorry... I've had bad experiences in the past where I accidentally posted on a not so correct board and the post never got answered. I guess I overreacted...
update: Apologies for the other messages--I was able to remove them. This is the only thread on this topic.
Reply 3 of 8, by wd
Rank DOSBox Author
DOSBox Author
Now post some info to get this closer to something where somebody can help you.
Reply 4 of 8, by sidv88
I've already posted the relevant details; particularly in regards to glidos, which uses a prearranged special version of dosbox that already has all the details set.
I have been fortunate to get in contact with the glidos dev since I first posted this question, who provided some insight--it's possible dosbox is simply overwhelmed in trying to play redbook audio and emulate 3dfx, affecting the music playback.
Reply 5 of 8, by DosFreak
You can try try to run the game in software mode and see if that makes a difference
Also try a SVN build of DOSBox
and also try using imgmount in DOSBox and mount a .bin/.cue of the CD
Make your games work offline
Reply 6 of 8, by wd
Rank DOSBox Author
DOSBox Author
No you didn't. You did not even post BASIC stuff as system specs.
Reply 7 of 8, by sidv88
With all due respect, the glidos dev felt that what I had posted was sufficient (that was why I had posted on that board, until I deleted it at people's request). I feel my communication with them has sufficiently answered my question and there is no need for others to keep pressing. I just wanted to keep my details private until I could figure out whether others had encountered this problem before.
Reply 8 of 8, by wd
Rank DOSBox Author
DOSBox Author
Ok.
