First post, by artifex
- Newbie
I have a game and I cannot run under DOSBox. I try different settings (video, memory, cpu, speed) but no luck. The executable starts but then black screen only or sometimes some garbage on the screen. I try with debugger but no success. Under the debugger I ran through unpacker but then executable starts to use different ports (3C8, 3DA) and when I press run and break the run after a little time then there was only garbage in the memory.
I ran several years ago with success but I did not save the config file. I remember that I had to play with speed of emulation most likely because it's protection or unpacker depend heavily on machine speed (or might vga/ega/anything interrupt).
So if anyone had success and know how to run, please help me.
The program is Crazy Bomber from Dynasty written in 1993.
