First post, by filipetolhuizen
Hi,
I'm using the latest DOS Box build by Taewoong (r3752) and I'm experiencing crashes with Corridor 7 CD version (the disk version works fine). The game crashes in the end of the first intro video with a Uncached Sound error message. If I skip the video it will work until many simultaneous sounds are played and will crash with the same error. I tried several configuration options, such as disabling cards emulation other than sound blaster, several sound blater types, different emulated CPUs, cycles (the game won't recognize any sound card if not running at max cycles). Is there anything I'm missing? It used to work fine with previous dosbox versions. Here is my dosbox config:
  • # This is the configurationfile for DOSBox SVN. (Please use the latest version of DOSBox)
    # Lines starting with a # are commentlines and are ignored by DOSBox.
    # They are used to (briefly) document the effect of each option.
    [sdl]
    # fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
    # fulldouble: Use double buffering in fullscreen. It can reduce screen flickering, but it can also result in a slow DOSBox.
    # fullresolution: What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
    # Using your monitor's native resolution with aspect=true might give the best results.
    # If you end up with small window on a large screen, try an output different from surface.
    # windowresolution: Scale the window to this size IF the output device supports hardware scaling.
    # (output=surface does not!)
    # output: What video system to use for output.
    # Possible values: surface, overlay, opengl, openglnb, openglhq, ddraw, direct3d.
    # autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
    # sensitivity: Mouse sensitivity.
    # waitonerror: Wait before closing the console if dosbox has an error.
    # priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
    # pause is only valid for the second entry.
    # Possible values: lowest, lower, normal, higher, highest, pause.
    # mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the defaul value.
    # pixelshader: Pixelshader program (effect file must be in Shaders subdirectory).
    # usescancodes: Avoid usage of symkeys, might not work on all operating systems.
    # overscan: Width of overscan border (0 to 10). (works only if output=surface)
    fullscreen=false
    fulldouble=true
    fullresolution=original
    windowresolution=original
    output=opengl
    autolock=true
    sensitivity=100
    waitonerror=true
    priority=highest,normal
    mapperfile=mapper-SVN.map
    pixelshader=none
    usescancodes=true
    overscan=0
    [dosbox]
    # language: Select another language file.
    # machine: The type of machine DOSBox tries to emulate.
    # Possible values: hercules, cga, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe, amstrad.
    # vmemsize: Amount of video memory in megabytes.
    # The maximum resolution and color depth the svga_s3 will be able to display
    # is determined by this value.
    # 0: 512k (800x600 at 256 colors)
    # 1: 1024x768 at 256 colors or 800x600 at 64k colors
    # 2: 1600x1200 at 256 colors or 1024x768 at 64k colors or 640x480 at 16M colors
    # 4: 1600x1200 at 64k colors or 1024x768 at 16M colors
    # 8: up to 1600x1200 at 16M colors
    # For build engine games, use more memory than in the list above so it can
    # use triple buffering and thus won't flicker.
    # captures: Directory where things like wave, midi, screenshot get captured.
    # memsize: Amount of memory DOSBox has in megabytes.
    # This value is best left at its default to avoid problems with some games,
    # though few games might require a higher value.
    # There is generally no speed advantage when raising this value.
    language=
    machine=svga_s3
    vmemsize=32
    captures=capture
    memsize=127
    [log]
    # logfile: file where the log messages will be saved to
    # vga: Enable/Disable logging of this type.
    # vgagfx: Enable/Disable logging of this type.
    # vgamisc: Enable/Disable logging of this type.
    # int10: Enable/Disable logging of this type.
    # sblaster: Enable/Disable logging of this type.
    # dma_control: Enable/Disable logging of this type.
    # fpu: Enable/Disable logging of this type.
    # cpu: Enable/Disable logging of this type.
    # paging: Enable/Disable logging of this type.
    # fcb: Enable/Disable logging of this type.
    # files: Enable/Disable logging of this type.
    # ioctl: Enable/Disable logging of this type.
    # exec: Enable/Disable logging of this type.
    # dosmisc: Enable/Disable logging of this type.
    # pit: Enable/Disable logging of this type.
    # keyboard: Enable/Disable logging of this type.
    # pic: Enable/Disable logging of this type.
    # mouse: Enable/Disable logging of this type.
    # bios: Enable/Disable logging of this type.
    # gui: Enable/Disable logging of this type.
    # misc: Enable/Disable logging of this type.
    # io: Enable/Disable logging of this type.
    # pci: Enable/Disable logging of this type.
    logfile=
    vga=true
    vgagfx=true
    vgamisc=true
    int10=true
    sblaster=true
    dma_control=true
    fpu=true
    cpu=true
    paging=true
    fcb=true
    files=true
    ioctl=true
    exec=true
    dosmisc=true
    pit=true
    keyboard=true
    pic=true
    mouse=true
    bios=true
    gui=true
    misc=true
    io=true
    pci=true
    [render]
    # frameskip: How many frames DOSBox skips before drawing one.
    # aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!.
    # linewise: Draw the display line by line. Needed for certain special graphics effects in games and demos. Can be changed at runtime but will be put in effect at the next mode switch.
    # char9: Allow 9-pixel wide text mode fonts.
    # multiscan: Set this value to true to allow zooming gfx effects used in demos. It will disable several options such as scalers though.
    # scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,
    # then the scaler will be used even if the result might not be desired.
    # Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x, hardware2x, hardware3x.
    frameskip=0
    aspect=false
    linewise=false
    char9=false
    multiscan=true
    scaler=hq3x
    [vsync]
    # vsyncmode: Synchronize vsync timing to the host display. Requires calibration within dosbox.
    # Possible values: off, on, force, host.
    # vsyncrate: Vsync rate used if vsync is enabled. Ignored if vsyncmode is set to host (win32).
    # Possible values:.
    vsyncmode=off
    vsyncrate=120
    [cpu]
    # core: CPU Core used in emulation. auto will switch to dynamic if available and
    # appropriate.
    # Possible values: auto, dynamic, normal, full, simple.
    # cputype: CPU Type used in emulation. auto emulates a 486 which tolerates Pentium instructions.
    # Possible values: auto, 386, 486, pentium, 386_prefetch.
    # cycles: Amount of instructions DOSBox tries to emulate each millisecond.
    # Setting this value too high results in sound dropouts and lags.
    # Cycles can be set in 3 ways:
    # 'auto' tries to guess what a game needs.
    # It usually works, but can fail for certain games.
    # 'fixed #number' will set a fixed amount of cycles. This is what you usually
    # need if 'auto' fails (Example: fixed 4000).
    # 'max' will allocate as much cycles as your computer is able to
    # handle.
    # Possible values: auto, fixed, max.
    # cycleup: Amount of cycles to decrease/increase with keycombos.(CTRL-F11/CTRL-F12)
    # cycledown: Setting it lower than 100 will be a percentage.
    core=dynamic
    cputype=pentium
    cycles=max
    cycleup=10
    cycledown=20
    [mixer]
    # nosound: Enable silent mode, sound is still emulated though.
    # swapstereo: Swaps the left and right stereo channels.
    # rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
    # Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
    # blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
    # Possible values: 1024, 2048, 4096, 8192, 512, 256.
    # prebuffer: How many milliseconds of data to keep on top of the blocksize.
    nosound=false
    swapstereo=false
    rate=48000
    blocksize=1024
    prebuffer=20
    [midi]
    # mpu401: Type of MPU-401 to emulate.
    # Possible values: intelligent, uart, none.
    # mididevice: Device that will receive the MIDI data from MPU-401.
    # Possible values: default, win32, alsa, oss, coreaudio, coremidi, mt32, synth, timidity, none.
    # midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
    # When using a Roland MT-32 rev. 0 as midi output device, some games may require a delay in order to prevent 'buffer overflow' issues.
    # In that case, add 'delaysysex', for example: midiconfig=2 delaysysex
    # See the README/Manual for more details.
    # mt32ReverseStereo: Reverse stereo channels for MT-32 output
    # Possible values: off, on.
    # mt32DAC: MT-32 DAC input mode
    # Nice = 0 - default
    # Produces samples at double the volume, without tricks.
    # Higher quality than the real devices
    # Pure = 1
    # Produces samples that exactly match the bits output from the emulated LA32.
    # Nicer overdrive characteristics than the DAC hacks (it simply clips samples within range)
    # Much less likely to overdrive than any other mode.
    # Half the volume of any of the other modes, meaning its volume relative to the reverb
    # output when mixed together directly will sound wrong. So, reverb level must be lowered.
    # Perfect for developers while debugging 😀
    # GENERATION1 = 2
    # Re-orders the LA32 output bits as in early generation MT-32s (according to Wikipedia).
    # Bit order at DAC (where each number represents the original LA32 output bit number, and XX means the bit is always low):
    # 15 13 12 11 10 09 08 07 06 05 04 03 02 01 00 XX
    # GENERATION2 = 3
    # Re-orders the LA32 output bits as in later geneerations (personally confirmed on my CM-32L - KG).
    # Bit order at DAC (where each number represents the original LA32 output bit number):
    # 15 13 12 11 10 09 08 07 06 05 04 03 02 01 00 14
    # Possible values: 0, 1, 2, 3, auto.
    # mt32reverb.mode: MT-32 reverb mode
    # mt32reverb.time: MT-32 reverb time
    # Possible values: 0, 1, 2, 3, 4, 5, 6, 7.
    # mt32reverb.level: MT-32 reverb level
    mpu401=intelligent
    mididevice=default
    midiconfig=
    mt32ReverseStereo=off
    mt32DAC=auto
    mt32reverb.mode=auto
    mt32reverb.time=5
    mt32reverb.level=3
    [debug]
    [sblaster]
    # sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
    # Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
    # sbbase: The IO address of the soundblaster.
    # Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
    # irq: The IRQ number of the soundblaster.
    # Possible values: 7, 5, 3, 9, 10, 11, 12.
    # dma: The DMA number of the soundblaster.
    # Possible values: 1, 5, 0, 3, 6, 7.
    # hdma: The High DMA number of the soundblaster.
    # sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
    # oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type.
    # All OPL modes are Adlib-compatible, except for 'cms'. sbtype=none
    # together with oplmode=cms will emulate a Gameblaster.
    # Possible values: auto, cms, opl2, dualopl2, opl3, none, hardware, hardwaregb.
    # oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
    # Possible values: default, compat, fast.
    # oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
    # Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
    # hardwarebase: base address of the real hardware soundblaster:
    # 210,220,230,240,250,260,280
    sbtype=sb16
    sbbase=220
    irq=5
    dma=1
    hdma=5
    sbmixer=true
    oplmode=auto
    oplemu=default
    oplrate=48000
    hardwarebase=220
    [gus]
    # gus: Enable the Gravis Ultrasound emulation.
    # gusrate: Sample rate of Ultrasound emulation.
    # gusbase: The IO base address of the Gravis Ultrasound.
    # Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
    # gusirq: The IRQ number of the Gravis Ultrasound.
    # Possible values: 5, 3, 7, 9, 10, 11, 12.
    # gusdma: The DMA channel of the Gravis Ultrasound.
    # Possible values: 3, 0, 1, 5, 6, 7.
    # ultradir: Path to Ultrasound directory. In this directory
    # there should be a MIDI directory that contains
    # the patch files for GUS playback. Patch sets used
    # with Timidity should work fine.
    gus=true
    gusrate=48000
    gusbase=240
    gusirq=7
    gusdma=3
    ultradir=C:\ULTRASND
    [innova]
    # innova: Enable the Innovation SSI-2001 emulation.
    # samplerate: Sample rate of Innovation SSI-2001 emulation
    # sidbase: SID base port (typically 280h).
    # quality: Set SID emulation quality level (0 to 3).
    # Possible values: 0, 1, 2, 3.
    innova=false
    samplerate=48000
    sidbase=280
    quality=0
    [speaker]
    # pcspeaker: Enable PC-Speaker emulation.
    # pcrate: Sample rate of the PC-Speaker sound generation.
    # tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
    # Possible values: auto, on, off.
    # tandyrate: Sample rate of the Tandy 3-Voice generation.
    # disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
    # ps1audio: Enable PS1 audio emulation.
    # ps1audiorate: Sample rate of the PS1 audio emulation.
    pcspeaker=true
    pcrate=48000
    tandy=auto
    tandyrate=48000
    disney=false
    ps1audio=auto
    ps1audiorate=48000
    [joystick]
    # joysticktype: Type of joystick to emulate: auto (default), none,
    # 2axis (supports two joysticks),
    # 4axis (supports one joystick, first joystick used),
    # 4axis_2 (supports one joystick, second joystick used),
    # fcs (Thrustmaster), ch (CH Flightstick).
    # none disables joystick emulation.
    # auto chooses emulation depending on real joystick(s).
    # (Remember to reset dosbox's mapperfile if you saved it earlier)
    # Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
    # timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
    # autofire: continuously fires as long as you keep the button pressed.
    # swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
    # buttonwrap: enable button wrapping at the number of emulated buttons.
    joysticktype=auto
    timed=true
    autofire=false
    swap34=false
    buttonwrap=false
    [serial]
    # serial1: set type of device connected to com port.
    # Can be disabled, dummy, modem, nullmodem, directserial.
    # Additional parameters must be in the same line in the form of
    # parameter:value. Parameter for all types is irq (optional).
    # for directserial: realport (required), rxdelay (optional).
    # (realport:COM1 realport:ttyS0).
    # for modem: listenport (optional).
    # for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
    # transparent, port, inhsocket (all optional).
    # Example: serial1=modem listenport:5000
    # Possible values: dummy, disabled, modem, nullmodem, directserial.
    # serial2: see serial1
    # serial3: see serial1
    # serial4: see serial1
    serial1=dummy
    serial2=dummy
    serial3=disabled
    serial4=disabled
    [printer]
    # printer: Enable printer emulation.
    # dpi: Resolution of printer (default 360).
    # width: Width of paper in 1/10 inch (default 85 = 8.5'').
    # height: Height of paper in 1/10 inch (default 110 = 11.0'').
    # printoutput: Output method for finished pages:
    # png : Creates PNG images (default)
    # ps : Creates Postscript
    # bmp : Creates BMP images (very huge files, not recommend)
    # printer : Send to an actual printer (Print dialog will appear)
    # multipage: Adds all pages to one Postscript file or printer job until CTRL-F2 is pressed.
    # docpath: The path where the output files are stored.
    # timeout: (in milliseconds) if nonzero: the time the page will
    # be ejected automatically after when no more data
    # arrives at the printer.
    printer=true
    dpi=360
    width=85
    height=110
    printoutput=png
    multipage=false
    docpath=.
    timeout=0
    [parallel]
    # parallel1: parallel1-3 -- set type of device connected to lpt port.
    # Can be:
    # reallpt (direct parallel port passthrough using Porttalk),
    # file (records data to a file or passes it to a device),
    # printer (virtual dot-matrix printer, see [printer] section)
    # parameter:value.
    # for reallpt:
    # Windows:
    # realbase (the base address of your real parallel port).
    # Default: 378
    # ecpbase (base address of the ECP registers, optional).
    # Linux: realport (the parallel port device i.e. /dev/parport0).
    # for file:
    # dev:<devname> (i.e. dev:lpt1) to forward data to a device,
    # or append:<file> appends data to the specified file.
    # Without the above parameters data is written to files in the capture dir.
    # Additional parameters: timeout:<milliseconds> = how long to wait before
    # closing the file on inactivity (default:500), addFF to add a formfeed when
    # closing, addLF to add a linefeed if the app doesn't, cp:<codepage number>
    # to perform codepage translation, i.e. cp:437
    # for printer:
    # printer still has it's own configuration section above.
    # parallel2: see parallel1
    # parallel3: see parallel1
    parallel1=disabled
    parallel2=disabled
    parallel3=disabled
    [glide]
    # glide: Enable glide emulation: true,false,emu.
    # grport: I/O port to use for host communication.
    # lfb: LFB access: full,read,write,none.
    glide=true
    grport=600
    lfb=full
    [dos]
    # xms: Enable XMS support.
    # ems: Enable EMS support. The default (=true) provides the best
    # compatibility but certain applications may run better with
    # other choices, or require EMS support to be disabled (=false)
    # to work at all.
    # Possible values: true, emsboard, emm386, false.
    # umb: Enable UMB support.
    # automount: Enable automatic mount.
    # keyboardlayout: Language code of the keyboard layout (or none).
    xms=true
    ems=true
    umb=true
    automount=true
    keyboardlayout=auto
    files=127
    [ipx]
    # ipx: Enable ipx over UDP/IP emulation.
    ipx=false
    [ne2000]
    # ne2000: Enable Ethernet passthrough. Requires [Win]Pcap.
    # nicbase: The base address of the NE2000 board.
    # nicirq: The interrupt it uses. Note serial2 uses IRQ3 as default.
    # macaddr: The physical address the emulator will use on your network.
    # If you have multiple DOSBoxes running on your network,
    # this has to be changed for each. AC:DE:48 is an address range reserved for
    # private use, so modify the last three number blocks.
    # I.e. AC:DE:48:88:99:AB.
    # realnic: Specifies which of your network interfaces is used.
    # Write 'list' here to see the list of devices in the
    # Status Window. Then make your choice and put either the
    # interface number (2 or something) or a part of your adapters
    # name, e.g. VIA here.
    ne2000=true
    nicbase=300
    nicirq=3
    macaddr=AC:DE:48:88:99:AA
    realnic=list
    [autoexec]
    # Lines in this section will be run at startup.
    # You can put your MOUNT lines here.
    @echo off
    mount c c:\jogos
    mount d d:\filipe
Reply 1 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Best try with plain 0.74 Dosbox or even better a pure SVN built, whether the game works there. Also try with a clean conf ( for example memsize shouldn't be that exceedingly big - most games are happy with 16, some rare ones won't like above that, some won't like above 32).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 3, by filipetolhuizen
Nevermind, I just found out that the game doesn't like being a virtual CD and played on the same directory. Playing using the original CD fixed the problem.
Reply 3 of 3, by SKARDAVNELNATE
You can image it as a bin/cue set.
