First post, by roarkes
- Newbie
When i run 2 games at once with dosbox (GOG games) GOG say the below thing, in the image. How can i resolve this ? I want to run 2 different games in dosbox at once.
You need to ask gog problems on gog.com 😉
It's possible that the shortcut in the Startmenu uses GOGwrap directly? Mabye using the DOSBox.exe directly in the installed folder will do what you are looking for.
You can run GOG games with any DOSBox installation. You just have to launch DOSBox with the appropriate parameter. If you look at the properties of the shortcut to your game, you will see something like this:
"C:\Program Files\Heroes of Might and Magic 2 GOLD\gogwrap.exe" GOGHOMM2GOLD
If you wan't to launch it and bypass gogwrap you have to locate DOSBox on your hardware and launch it with the appropriate .conf file. In the case of HOMM2 on my PC it would be:
"C:\Program Files\DosBOX\dosbox.exe" -conf "C:\Program Files\Heroes of Might and Magic 2 GOLD\dosboxhomm2.conf"
