First post, by Dhall
Hi!
I was wondering if you could help me out with a little (huge?) problem here.
Recently I started putting together a retro rig, just for the sake of fun. I even acquired a classic GUS from a friend.
I would like to install this sound card in MS-Dos 6.22.
I have an Asus P2B motherboard which has 3 ISA slots. I tried all of them, but to no avail. I installed the stuff from the original GUS install cd and everything is fine up till I try to use the card itself.
In the Ultrasnd dir I ran playmidi and when I chose a MIDI file, the program informs me that a GUS card was not found. It is the same with games.
I even tried in the bios to manually set irq 5 for "legacy card". Note that this is the only isa card on the motherboard, the only other card is a PCI S3Virge.
I'm getting a bit desperate here because I payed good money for this card and heard much about its capabilities... 😢
Thank you in advance
Reply 1 of 15, by megatron-uk
What install cd did you use? The original cards came with a set of floppy disks.
Anyway, did the setup routine detect and configure all of the card settings? base address, interrupts etc? What did it leave your autoexec.bat looking like?
https://www.target-earth.net
Reply 2 of 15, by Dhall
The Cd is titled : The Ultrasound Cd
Subtitle: Over 100 Mb of software
I installed the software which created a dir called ultrasnd. I cannot run setup.exe as of right now, because it tells me I don1t have enough conventional memory (I have 515k it needs 550) I'm working on it right now.
In the meantime, I checked msd.exe and it registers as a game port.
Reply 3 of 15, by Dhall
Ok, so I fiddled around with autoexec.bat and config.sys and managed to free up enough memory to run setup.exe. The setup configured the irq and dma smoothly.
Now I started up some games and I would only like to say that I have never been so happy in my life. Thanks megatron for the help. I think I will lose my head now. tralalalala
However..I'm worried about the beaver competition.
Reply 4 of 15, by megatron-uk
How much memory does your card have? You can download the Pro Patches Lite pack which replaces the standard instrument patches with enhanced ones - it really makes a difference to the music quality!
Reply 5 of 15, by Dhall
I think the card is "full" so that means 1 Mb? Can you tell me a bit about those Pro patches? To be honest I don't really know much about this card so ANY kind information is much appreciated.
I'm particularly interested in the jumper settings on the card . I didn't find anything on those...
Reply 6 of 15, by elianda
There is not much to consider. You just set the port and everything else is set by Ultrinit from software side.
Youtube Channel
Reply 7 of 15, by megatron-uk
Standard instrument patches: http://www.youtube.com/watch?v=jtynM2jKGyw
Pro Patches Lite: http://www.youtube.com/watch?v=4zSh0sPw2Qk
Link to diiferent patch sets: http://www.gravisultrasound.org/downloads/ult … ort.php#patches
Reply 8 of 15, by Dhall
Thank you very much for the links, I will try them very soon.
Reply 9 of 15, by Dhall
Okay, I downloaded them. I'm trying to install the 1.50 lite pack but when I do everything as the txt tells me, patmenu.exe S exits with a runtime error.
I installed the 4.10 and then the 4.11 soft overmy original install.
In the autoexec.bat I have to variables set
SET PROPATS=c:\GUSPAT
SET ULTRADIR=C:\ULTRASND
The patmenu exits with a "Runtime error 200 at 0415:0091" I read a forum topic on this here at zetafleet but that just told me to set the ULTRADIR variable, which I have done already.
Reply 10 of 15, by 5u3
If your CPU is faster than ~200ish MHz, it's likely to be caused by the Borland Pascal delay bug. Try slowing down your machine.
Reply 11 of 15, by Dhall
Yes, unfortunately I'm using a slot1 motherboard with a pII 400. I'm still hunting for parts for this computer and in the meantime I'm using it with this cpu. Thanks for your suggestion, I will try to slow it down in the BIOS...
Reply 12 of 15, by Dhall
Well, there is no way (which I know of) to slow done this cpu in MS-DOS. Not in the BIOS, not with jumpers on the board.
So my question is: Can I install the pro patches without patmenu.exe?
Reply 14 of 15, by Dhall
Thanks Donutking, I am able to run patmenu now, but it immediately exits after the blue "processing patch files" screen with runtime error 005 at 0000:1CE5......
Reply 15 of 15, by Dhall
Hmmm I tried to cheat my way through by copying an already ppl 161 ultrasnd dir, but it just won't work
