First post, by sliderider
Does anyone know if these can be run safely at 200mhz?
Reply 1 of 7, by luckybob
180 to 200? I'd wager 99% of the cips made would do that with no issues.
Reply 2 of 7, by sliderider
I thought as much. I just wondered why they labeled some 180 and others as 200.
Reply 3 of 7, by luckybob
so they could charge more for the 200 than the 180 is the most likely answer.
Reply 4 of 7, by Robin4
Why would you do that, then you better could buy an 200 mhz one.
OC your chip would draw more power then use a stock 200mhz one.
Reply 5 of 7, by bushwack
I ran my old 166 MMX at 200 back in the day with no problems so I say go for it. 233 or even 266 shouldn't be a problem either with good cooling.
Is yours a ceramic chip or the newer organic style? The newer organic, black with silver cap, chips overclock a little better then the older style ceramic chips.
Reply 6 of 7, by sliderider
Because I got a 180mhz one for $13. Have you seen the prices overdrives go for?
Reply 7 of 7, by sgt76
Same here, my 166mmx ran at 200mhz it's whole life so 180-> 200 vitually a given.
