Windows 98 problem
First post, by Eimer
I know Windows 98 is not officially supported but I followed this tutorial: (Guide) How to Install Win98se with 3dfx driver in Dosbox
and did everything what it says, using ykhwong's latest build.
During Windows Setup in the latest 7 Minutes the Setup keeps freezing after showing an error that RunDll32 had to be closed.
The console is showing up the following errors:
Illegal read from c27dd001, CS:IP       28:c02322b1
Illegal read from c27dd002, CS:IP 28:c02322b1
Illegal read from c27dd003, CS:IP 28:c02322b1
Illegal write to c27dd000, CS:IP 28:c02322b1
Illegal write to c27dd001, CS:IP 28:c02322b1
Illegal write to c27dd002, CS:IP 28:c02322b1
Illegal write to c27dd003, CS:IP 28:c02322b1
what does that mean and how can I fix this?
Reply 1 of 1, by wd
Rank DOSBox Author
DOSBox Author
don't do it
