First post, by cdoublejj
- Oldbie
So i have an older laptop, came new with ME but, have been running 98se for longest time on it. any who i have 120gb ide hdd in it and after the final boot in install (where it stops running off the cd and starts running off the hdd) it acts like nothing is there. it just sits there blinking "_" like the hdd is empty.
i've been through this a million times and very familiar with partitioning. i've tried a smaller part for the os only and what not double checked it was fat32 LBA blah blah.
my next step i guess is to try and get grub to find the needed files to make it boot. i've double checked it does indeed install files to the drive.
the shitty part is that i did get it to work but, had forgotten to wipe the drive and so my root was full of all kinds of random stuff and the drive name was "WD passport" (portable hdd), so i launched part logic and cleared it out, and now it refuses to finish installing.
is there a file i manually load to kick start it? is it the file system i set up part logic/g parted? do i need to make it raw and let 98se installer partition/format it?
I'm using a later installer that doesn't need that dumb boot floppy it's all stream lined so to speak. Also before i ended up needing to reinstall i used to dual boot with linux with grub but, as i said before it installed to the FULL drive as it was with all the crap on it.
not to confuse you it is a different hdd than the one i dual booted on but, is of the same size and physically fit and also ide.
