Dosbox question
First post, by jmcinvale
I am running Dosbox on a laptop running Windows Vista with ATI graphics and have a question.
I have a HDTV connected to the VGA connector as a second monitor. I want Dosbox to run full screen on the second monitor, but when I switch to full screen it defaults to the laptop display. Any way to fix it?
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
AFAIK there is no way to fix this. It's a limitation of SDL. BUT if I remember Windows correctly you can switch first and second monitor, so the TV is seen as first one.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 2, by jmcinvale
Yes that is possible on a desktop, but not a laptop.
If the laptop had Nvidia graphics I could just send the application to the other monitor.
I got it. There is a button that switches the laptop display off and sends it to the external monitor.
