First post, by Jorpho
- l33t++
Say you've got a bunch of CPUs you want to test, and they're sufficiently fast that they'll probably burn up pretty quickly if they're used without some kind of cooler. (There are lots of those, right?)
If you don't want to go through the trouble of cleaning the CPU, applying more thermal compound, and carefully re-attaching the heatsink, is there any good way to keep the CPU cool for long enough to see if it boots in a particular motherboard? Can you just point an electric fan at it, for instance?
