First post, by maddmaxstar
- Member
Hey there, I touched on this a bit in my post in "Milliways>Bought these Retro Hardware today" thread, but I posted that I'd gotten a bunch of PIII CPUs to try and get one to work in my 370 box - Tetrium suggested I post a thread about it here.
So, the machine looks like this:
The machine is a system built out of a crappy purple iDOT Explora case that I've nicknamed "Barney"... Inside I have a mATX AOpen MX3W Pro-V motherboard using an Intel i810 chipset.
The issue is this: This board reportedly supports VIA C3 processors, which I just bought a C3 733 (5.5x133) off eBay a few days ago...
However, according to the AOpen website, the board does not technically support 133MHz FSB chips, but does have BIOS strings for 133MHz CPUs (since it shares it's BIOS with the i810E based MX3W Pro-E), and does have 133MHz options in the BIOS. The PIII 650 that's currently installed successfully posted at 866MHz (6.5x133 - the BIOS won't allow lowering the multiplier) before freezing.
Thinking it might support 133MHz FSB PIII's, I got 3 PIII's to test in the system, a PIII 733, PIII 800EB, and PIII 1000 of which none of them would post. I also tried a Tualatin based 100FSB Celeron 1300, but it didn't work either (not that I was expecting it would, the board specs state that it'll support voltages as far down as 1.3v, but Tualatins probably weren't supported by the BIOS).
The BIOS has been updated to version R1.33, which is actually a more recent revision than whats available on the AOpen website (R1.32). In case of discrepancy I flashed it to R1.32 and tried the chips that way as well.
Now, I'm pretty sure I'm gonna be stuck into getting a new board for the C3, but I figured it would be a good idea to check here to see if anyone has any ideas, has any experience with this board or knows of a hacked BIOS.
= Phenom II X6 1090T(HD4850) =
= K7-550(V3-3000) =
= K6-2+ 500(V3-2000) =
= Pentium 75 Gold(Voodoo1) =
= Am486DX4-120(3DXpression+) =
= TI486DLC-40(T8900D) =
= i386sx-16+i387(T8900D) =
