How this cleaning disk works?
First post, by Robin4
Does anybody knows how this BASF Cleaning Flexy Disk 5.25 works?
Do i need to have some cleaning liquid on it, or are there cleaning disk that works on dry surface?
I know i need to turn it around 180 degrees to clean both heads..
Reply 1 of 21, by BigBodZod
Yes, you need some cleaning fluid but you should be able to substitute Denatured Alcohol of 95 percent or better.
Also they have both sides open so a double-sided floppy drive should work fine.
No matter where you go, there you are...
Reply 2 of 21, by Robin4
What happend if i dont use the cleaning liquid? Raping the heads of the drive?
Iam have order some of Isopropyl Alcohol 99.9% Pure 100ml. So i hope that would do the trick. Only wait when its arrives.
Reply 3 of 21, by BigBodZod
Well I would think that it just wears out the R/W heads faster then if you use it *with* cleaning solution 😉
Reply 4 of 21, by RoyBatty
I just use Isopropyl Alcohol and a couple of Q-tips, the heads are glass coated anyways, so it's not an issue what % it is as long as it's 90% or more.
Reply 5 of 21, by fronzel
I used Vodka on mine and that worked as well. Prolly not as great as pure alcohol, but hell after youre done cleaning you can still have a vodka coke. So far the drive didnt rust or stuff if anyone was expecting that, but i also didnt make the disk soaking wet.
Reply 7 of 21, by Robin4
A Q-tip isnt handy when there is a PCB above the drive.. And it isnt worth to dissamble the whole unit, for only cleaning the heads.. Now i only have to put the disk in and its clean..
Today i received my hoped ISOPROPANOL ALCOHOL, so if i have time iam going to try it out a sees if it would work..
http://www.ebay.com/itm/IPA-Isopropyl-Alcohol … 297078669499588
Reply 8 of 21, by Tetrium
I remember having partially disassembled such a drive. The heads were relatively easy to reach, but it's been years since I done that. And anyway, that way I won't have to buy a cleaning disk, I'm probably not going to be using the 5 1/4 drives a lot (maybe just for kicks 😁 )
My retro rigs (old topic)
Report spammers here!
Reply 9 of 21, by Jorpho
That's really kind of overkill, considering how much more expensive it's likely to be. But then, I suppose the price difference doesn't amount to much if you're only dealing with one small bottle.
Reply 10 of 21, by Robin4
Actually it was very cheap!
Reply 11 of 21, by Robin4
Cleaning didnt work. Think the heads are dead.. He is trying to read.. then get an error.. Trying to format a B floppy and says the drive is busy.
And the heads of the q-tip are to big to get them between the heads..
Reply 14 of 21, by Tetrium
fronzel wrote:
If the head is clean and not damaged the disk drive may need alignment.
http://apple2.info/wiki/index.php?title=Flopp … Drive_Alignment
I'm actually worried about this problem when it's my non-1.44 floppy drives. Is it possible to re-align them again? Preferably in an easy and cheap way? 😁
Reply 15 of 21, by fronzel
Normally only 5.25 inch floppy and older were prone to requiring allignment - 3.5 Inch ones usually should not require (or even offer an ability ) to allign them. For 3.5 inch floppy drives usually best you can do is clean the heads and pray they still work properly. But at least the later 3.5 inch drives are neither rare nor expensive.
Reply 16 of 21, by Chaniyth
I'd say align the heads of the drive, 5 1/4" drives were prone to dis-align, especially on the Commodore 64 1541 drives... not only were those drives loud and "chattered" alot, they dis-aligned often, especially if you were a Commodore pirate back in the day, or had access to pirated material. 🤣
Reply 17 of 21, by RoyBatty
The 1541 alignment thing is a myth, it was usually dirty heads. Only the first batch of them (the white ones) had alignment problems because the stepper shaft was made of a soft metal, not steel, so it actually twisted with repeated head banging. I have 25 year old drives which got used all day long for many years and they are still in perfect alignment. 1541's head get very dirty tho, but the q-top method is ideal for them 😁
Reply 18 of 21, by Robin4
Only need to look for an alignment disk.
Reply 19 of 21, by fronzel
An allignment disk will probably be expensive if you can even get one. A new 5.25 floppy drive will probably cost much less than an allugnment disk.
