First post, by maddmaxstar
I have a Matrox m3D, got it used out of a stack of recycle cards at work. I've had it for a few years now as a conversation piece and a collectors item, but just recently decided to put it in my K6-2+ and fire it up to see if the thing even works.
The card seems to have detected OK, drivers are installed, no resource conflicts, started and running under Win98se, no indication that the card is malfunctioning... I installed the OpenGL patches for Quake I & II, however, it does not appear to be running correctly.
Both Quake and Quake II when trying to initialize the PowerVR modes fail with the error message:
"ERROR: Unable to access one or more functions on SGL.LIB. Either your PowerVR Windows95 drivers are not installed or they are out of date. Please try installing the latest Windows95 drivers for your PowerVR card."
When I originally installed the card, I used the Matrox m3D drivers from the Matrox website. I uninstalled them and tried installing the Generic Videologic 4.1.2 drivers (using the Setup.exe) to see if that helps, but no effect, same crash.
Anybody out there know what I might be doing wrong? Is there any way to tell if my card is even working?
= Phenom II X6 1090T(HD4850) =
= K7-550(V3-3000) =
= K6-2+ 500(V3-2000) =
= Pentium 75 Gold(Voodoo1) =
= Am486DX4-120(3DXpression+) =
= TI486DLC-40(T8900D) =
= i386sx-16+i387(T8900D) =
Reply 1 of 10, by sliderider
Leileilol would be the one to ask about early PowerVR cards.
Reply 2 of 10, by Jan3Sobieski
Try resitting the card in it's PCI slot, or try a different slot.
There should be some PowerVR tech demos on the installation cd that you can install on your machine. if those work ok, the card is fine.
Reply 3 of 10, by leileilol
There's also a PNP bios setting that can interfere with the card's detection. I forgot what exactly it was though
long live PCem
FUCK "AI"
Reply 4 of 10, by retro games 100
I had similar trouble with an Apocalypse PCX2 PowerVR card recently. I tried various mobos, and various PCI slots. Eventually it worked. I came to the conclusion that my failed attempts were due to not using the card in a PCI slot that supported bus mastering. However, I don't know whether this is applicable to the Matrox M3D card. I would suggest trying all of the PCI slots on a couple of mobos.
Reply 5 of 10, by maddmaxstar
Cool, I'll try moving the card around. It's in PCI Slot #2, I seem to recall hearing something about Slot#2 sharing resources with the AGP slot. So in the end that sort of message means that the PCX2 is not responding?
= K7-550(V3-3000) =
Reply 6 of 10, by retro games 100
What you could try, just to see it working, is to remove the AGP card, and put in any PCI video card in slot #1. I would leave the M3D in slot #2. When I finally got the Apocalypse to work, I had this combo. BTW, I thought that slot #1 shared its resources with the AGP slot.
Reply 7 of 10, by leileilol
The PCX2 itself wouldn't care what its host card is by the way. It'll work with AGP 8x even. It'll even work with onboard VGA, and that's the worst performance bottleneck.
Also, in case you're going to try a PCX2/Geforce combo - I've experienced trouble with PCX2 and Geforce drivers, Nvidia made them aggressive to be their card as the absolute primary, which causes memory issues that leads to a instant crash where it'll just not work at all anymore for the running windows session
I should note the above blurb is relevant only for Direct3D... OpenGL and SGL are fine with PCX2+GF
long live PCem
FUCK "AI"
Reply 8 of 10, by maddmaxstar
It's partner card will be a Voodoo3. I'm hoping to use it with my Voodoo3 3000 so I can do TV out, maybe record some sample videos for my youtube channel, perhaps show some contrasts between Glide and SGL, for no other good reason than "because I can" 😜
However, that said, how does the PCX2 fair with PCIe boards? Not exactly a common thing, but has anyone tried?
= K7-550(V3-3000) =
Reply 9 of 10, by leileilol
🤣 THATS MY COMBO FOR MY PCX2 RECORDINGS
PCIe isn't available on Win9x, and PCX2 only had drivers for Win9x - you'll never find out the answer.
long live PCem
FUCK "AI"
Reply 10 of 10, by maddmaxstar
Damn the PCX2 is a finicky b**ch. I can confirm the card is working, but I had to clean the contacts with a white eraser, remove all PCI cards and try the card in each slot to check if it works.
Finally, the thing finally fired up in PCI Slot 1 (3rd try), directly adjacent to the passively cooled Voodoo3. Doesn't do a bad job running Quake or Quake II, I would have loved to have one of these back in 98-99 when all I had was a SiS6236.
So I put in a Cardslot Blower fan beside the card, swapped the Voodoo3 2000 for the 3000 from my Athlon 550, and reinstalled the Realtek 8139 NIC card. Everything reinstalled OK, but then the PowerVR stopped working. So I removed the 8139, sure enough, the PowerVR works.
So now I'm gonna try it with a 3Com 3C905-TX installed, and see if the PowerVR likes that better. If that doesn't work, I might have to try an ISA NIC. That's alot of work just to get a Budget 3D Card from 1997-99 working!
Now I know what Leileilol means by "hitting the PCX2 in the face until it works ."
= K7-550(V3-3000) =
