Floppy Disk
First post, by ik8ozv
Hi to the list,
i wanto to make an arj backup of my documents folder.
I have bought an external USB Floppy drive but
cannot get success to arj the files.
The arj program is in
C.\Totalcmd\Utility
and the fies are in
C:\Users\Enzo\Documents.
Which is the right procedure?
What to mount?
I hve tried to mount c:\
Plese any help?
Thanks in advance.
Enzo
Reply 1 of 18, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Why don't you just use Windows command line prompt? Or Totalcommander?
Why arj? That's ancient, rar and zip are much better IMO these days.
Back in dos days I only used arj but today....
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 18, by Dominus
DOSBox Moderator
But to answer your question:
mount a a:/ -t floppy
mount c c:/totalcmd/utility
mount d c:/users/enzo/documents
Then switch to c, start arj and let it backup d to a
Reply 4 of 18, by ik8ozv
I would like to use the Totalcmd as i done on Windows XP
but since i've passed to Windows 7 64 Bit it won't work.
When i try to pack the files trough Totalcmd i get the error that
it cannot find the external program even if i have set the right path in the
Totalcmd cfg.
If i try to run the arj.exe comand trough he Totalcmd i get the error:
Error executing program! (5)
Can you tell me why and if there is a possibility to run the comand trough the totalcmd as i done with Windws XP?
Any help will be really appreciated
Thanks in advance.
Enzo
Reply 5 of 18, by Dominus
DOSBox Moderator
you need to find at least a 32bit version of arj, 16bit programs (almost all dos programs) can't be run on 64bit Windows. Just use Winzip, Winrar for backing up. As I wrote earlier those bring much more useful stuff to the table these days. It's 2012, don't use a program made for the 20th century.
And don't use Dosbox with it. As Dsobox won't pass along long file names you are surely going to have problems with it.
Reply 6 of 18, by kolano
I'd advise 7zip...
http://www.7-zip.org/
...which unlike the suggestions of WinRAR/WinZip is freeware, and typically achieves slightly better compression than them as well.
Reply 7 of 18, by Jorpho
kolano wrote:
I'd advise 7zip...
True that. I suppose you could even take the source code for the command-prompt versions and change the command line arguments to make it work exactly the same way as Arj used to.
I still can't stand the UI of 7-Zip, though. I think there were some alternatives I was going to look at, but IZArc (which is free but not open-source) continues to meet my needs nicely.
Reply 8 of 18, by eL_PuSHeR
I think there is a ßeta Total Commander 64 bit now.
I would use 7-Zip too. Great compression and it's free.
Reply 10 of 18, by ik8ozv
Dominus wrote:
But to answer your question: […]
Please apologize if OT but i ma trying to format some diskette
with my USB Floppy Drive but i cannot get truogh.
Every time i try to format the format seems to do not work and to restart the comand i have to unplug and plug in again the USB Floppy drive.
It seems it takes long time to format.
Sometimes it stops in the middle of formatting
Sometimes i get error IOCTL
So i have tried with DosBox just in case the USB Floppy Drive
is not seen properly.
I have tried to put the comands above but when i launch the Format comand, i get the error that the comand cannot be run in Dos Mode.
Any help?
Reply 13 of 18, by VileR
Dominus wrote:
El_pusher, Total Commander isn't the issue, it's that TC uses the arj dos tool for archiving.
it's only this particular user of TC who seems to want to use arj...
Reply 15 of 18, by VileR
....miles away from you, for some reason. Gee, this thread could sure use more snarky comments, right?
Reply 16 of 18, by wd
Rank DOSBox Author
DOSBox Author
YOU ALL SUCK DISK (FLOPPY)
Reply 18 of 18, by wd
Rank DOSBox Author
DOSBox Author
hard disk?
