First post, by digiPixel
When running DOSBox it will exit fullscreen after about 10 minutes. The only way to get DOSBox back to fullscreen is to minimise it, and restore it. Once DOSBox is restored the same problem occurs again.
Using DOSBox 0.73 on Ubuntu 10.04. I suspect the issue may be related to SDL as a similar issue occurs when running Neverwinter Nights.
I think that SDL 1.2 is being used but I am not entirely sure.
Reply 1 of 1, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
There is some weirdness in your windows manager it seems to me. Anyway update all your stuff. Dosbox 0.73 is ancient by now, a new sdl is out etc.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
