Duke Nukem 3D problem
First post, by mgman
Ok, so before locking this, I've already tried everything suggested in the README and it doesn't help.
Basically, when I run Duke Nukem 3D through latest DOSBox, I get this error:
"Playback failed, possibly due to an invalid or conflicting DMA channel. Make sure the 16-bit DMA channel is correct."
I've seen topics with the same issue. However, in none of them were the problem solved (mod usually locked the topic, saying to look at the README).
Please help! Thanks!
Reply 1 of 7, by wd
Rank DOSBox Author
DOSBox Author
setup
Reply 2 of 7, by mgman
Do you often "help" people with messages as cryptic as this?
Reply 3 of 7, by R153nm
Run setup.exe and change your DMA channel in audio setup until it works correctly.
Reply 4 of 7, by wd
Rank DOSBox Author
DOSBox Author
No, I close the threads if the answers are obvious or could be found in 2 minutes via google.
Reply 5 of 7, by Zup
I guess you didn't play Duke Nukem 3D back in the day (and you know how to setup the game) nor bought it via Good Old Games (that made a installer that make your game runs fine).
Did you know that VOGONS doesn't suppor piracy?
I'm selling some stuff!
Reply 6 of 7, by leileilol
there's a shareware version
long live PCem
FUCK "AI"
