First post, by neo2403@gmx.de
hello we are using the old symantec f&a 4.0 in dox, we can print, its starts but we're using the using the f&a 4.0 in an multiuser area. the access to the dit datebases goes over a mapped network drive.
under win xp, we're starting the f&a 4.0 over the cmd (NOT dosbox)
if two ore more users using the same record in the dit datefile a message pops up the record is in work, because the access of the record will denied. thats correct.
in the the dosbox all user can access the same record, an the message (pop up) the record is in work is not working. i think it's a problem of the share.com or exe in dosbox. :depressed:
any ideas or is it really possible to use the share.exe with all function in dosbox (because the share.exe is running, but it helps not)
any ideas, i'm not a progi and f&a is a stranger for me. please help.
THANKS A LOT.
