First post, by Pato
Hi there, I am having problems compiling Dosbox 0.74 on Windows
I remember that compiling on linux is very easy, and gives great results on the part of performance, so I am trying the same on windows
I followed the wiki at first, but it didn’t compile, after a little search I found that the wiki have information that is misleading or incomplete. After searching for info on the web and reinstalling MinGW + stuff a lot, and reading a lot of information on how to install MSYS + SDL Correctly, I think I managed to almost compile it
Downloaded SDL, ./configure && Make && Make install, it compiles just fine
Downloaded SDL_Net, ./configure && Make && Make Install, compiles just fine
Even have ddraw.h as an include in MinGW, so I can have Directdraw support, if I am not mistaken (It shows correctly on ./configure)
But when I try to compile Dosbox, running ./configure && Make, see the image
http://s9.postimage.org/g60zo8zin/make.png
(CONFIG.LOG attached in the message)
Using the latest versions of Dosbox, MinGW, MSYS and SDL as of 10 / 02 / 2012
I am not sure what I am doing wrong, keep in mind that I am just an enthusiast trying to achieve better performance, does anybody knows what’s wrong? Thanks for the attention.
Reply 2 of 2, by Pato
WOW, I've used the SVN version 3778 and it worked on the first try! Thank you! That was the most useful two-word answer I've ever seen.
